for my firmware bitrate tools not work..say no array in PRI files...its firmware for finevu cr-2000
Yes, my DVR don't start after flashing modifed firmware. Even I just unpack and pack firmware. I have to recover my DVR by elf file.So I just checked your Firmware but I did not find a Problem. Can you tell me what did not work? Did you brick your dashcam?
I already tried a7tool 0.7.1, 0.7.2 and 0.7.3.I'll check it again...
Could you try to do this in the meantime: Use A7Tool v0.7.2 an do the same things you did with 0.7.3 and tell me if it works
Versions 0.6, 0.7, 0.7.2, 0.7.3 do not workSo it worked with None of them?
I've try to do this. It don't workOk could you try to decompile the original Firmware and recompile it without any changes? And then try if it works or not.
I have no idea where the Problem is located :s
