Do you think anything else in the hybrid could cause anything that would compromise the A188's performance (besides the already installed navigation system)?
Mine is in a Prius, no issues. I ran the power down the left side window molding, under the dash, to the lighter outlet in the center console storage area under the radio. Something like this:Do you think anything else in the hybrid could cause anything that would compromise the A188's performance (besides the already installed navigation system)?
honestly, adding electronic accessories such as a stereo, dashcam, alarm or dvd player is no different in a hybrid than it is in a regular car. the hybrid electrical system is completely isolated from the standard electricals, and all high voltage leads are wrapped with a distinctive, brightly-colored wire loom, just like how all airbag wiring is wrapped in yellow loom (in toyotas at least). so avoid any colored looms, and make sure any wires you add in the pillars don't get in the way of where an airbag will deploy to (just in case you need it), and you'll be fine.
so basically you have to watch out for the same things as in any other modern car - airbags and their wiring.
claimer: starting in 2001 i was a certified mechanic at a toyota dealer for almost 8 years and installed and serviced plenty of aftermarket goodies in both new and used cars.
well as long as you aren't trying to use this camera in parking mode (which apparently it's no good for anyway), then there shouldn't be an issue. if you hardwire it, just make sure that whichever circuit you tap into is actually key-switched. a good candidate would be the power windows or sunroof circuit - that's what i tapped into on my camry. The sienna didn't have a sunroof, so i tapped into the power supply line for the little trip "computer" in the overhead console - displays things like fuel economy, outside temp, distance to empty, and a compass. that way i didn't have to run any cables down the A-pillars in either car, thus making the install much easier. by using an existing circuit that the car itself controls, you don't have to worry about parasitic drain, and thus don't have to worry about the little 12v battery in your hybrid.A lot of what you say makes perfectly sense. However, on the modern Toyota Hybrids, there are things to look out for. The 12V battery for instance, is very small and disturbances could easily lead to a flat 12V battery. Just recently my model (among others) had a special firmware upgrade performed (regarding the combination instrument) to resolve this. Prior to this particular hybrid, I have had six other Toyotas, and the 12V batteries were significantly greater in capacity on these non-hybrid models.
By the way, I have also worked for Toyota, and now as a customer, I sometimes find that communications could be vastly improved, especially in Sweden, but that is totally OT i guess. 🙂
I'll add mine here too, on a 1970 VW Beetle
A 3 min snip of my commute home (nothing special happens) -
I like how the Veedub badge stands out in your video #thumbsup!
good video, and glad they didn't hit you... but this should be posted in the dashcam videos (videos taken by you) section of the forum. 🙂My new footage of a random idiot that beats the traffic light 😡
Finally got some pics of the A118 in my wife's 2008 Toyota Sienna minivan. from the outside it's actually very difficult to see, even up close - perfectly stealthy. i had a hard time getting my cameraphone to focus on the camera instead of reflections in the glass. in the exterior pictures, the camera is mounted just to the right of the black spot where the mirror attaches to the glass. very hard to see in all but the extreme closeup pics. which to me says this is a very stealthy camera. the white square to the left of the mirror mount is the toll road transponder sticker.
inside, the wire cover makes it look pretty much OEM. My wife likes the clean look - there are no exposed wires anywhere.
View attachment 8879 View attachment 8881 View attachment 8882View attachment 8883 View attachment 8884 View attachment 8885
Hey guys
Any ideas on the best place for purchase?
Is this dashcam the same as this? http://www.streetguardian.info/shop/sg9665gps-single-cam/
Close, ours is better 😉
If you want one let me know and I'll do something special for you
Hey mate, been a while! Thanks for the reply!
I'm very keen 🙂
Sure thing 🙂No problem, I'm out at the moment but will shoot you a message when I'm back in front of my computer
