joe384
- Aug 29, 2019
- Essex
- United Kingdom
- Viofo A139 3CH, A139 2CH, Mobius w/ Varifocal Zoom
Has anybody tried this FW ?
I flashed this firmware.. Done the reset pin, then formatted sd card. Then I stopped recording and went through the settings... Auto Event Dectection, Parking mode G-sensor high, parking move motion sensor low, put Wifi to 5Ghz plus some other bits.
As I came out the menu though the Wifi Icon with the timer popped up but is stuck there. Rec light (left) is solid on. Audio light (right) is solid on. Wifi light (middle) is off.
I tried power cycling it and the wifi icon still comes up and is stuck there. Tried the reset pin but it is still there when it powers up. None of the buttons have any effect (except for making a beeping sound)
I might try to reflash the firmware but if I still have issues I'll probably go back to v1.5 for the time being. I did turn on GPS even though the mount is still in the car. Could this be the cause?
Ok, just reflashed, reset pin and format card. Working ok so I went in to the Menu and just set Wifi to 5Ghz (no other settings). Backed out of Menu (Left most button?) and getting the same issue, Wifi icon stuck on screen (it normally flashes up briefly)
