@viofo
I installed and tested V1.8 but with auto event detection the cam stops recording randomly. So the problem from previous version was not solved...
The new buffered A129
Parking Auto Event Detection Mode is designed to only record clips when visual or impact event is detected
-or- remain in low power Standby Mode without recording to save memory card space.
The visual motion event recordings will now record 12 seconds prior to trigger event creating 45 second clips with
PF - front and
PR - rear added to clip file name.
What is displayed build date of installed v1.80 firmware?
What Loop Recording is selected? 1min /
2 / 3 / 10
What size brand memory card inserted?
Does parking mode issue occur in single camera and dual camera mode?
How is A129 connected to power? GPS mount /
side port
What is power source? vehicle battery using socket adapter / Hardwire kit3 / power bank
What is HK3wire voltage cutoff switch setting? 11.8 / 12.0 /
12.2 / 12.4
What is HK3 circuit taps? ACC / Battery / ground
How old is vehicle battery? 1 year / 2 / 3 / 4
What are conditions during parking test ? temperature / day / night / full sun / garage / workbench
