Dashmellow
- Sep 22, 2013
- Uncanny Valley (●_●)
- Umpteen
what res do you get in webcam mode?
1080 or at least it looks that way.
I haven't ever had the opportunity to try this and for sure the Mobius does some things much better than others are doing on the same platform with the enhancements they've done but I'm not aware of the webcam mode being capable of 1080p, if it's not and it's either cropped or compressed the adjustments you make in webcam mode won't match what it outputs in video mode so would be very hard to get the focus right using this method if this is the case, maybe confirm what res you get in this mode, if it is 1080p capable in webcam mode then it may just be a lens issue and something you'll never get right
It appears that I was shipped a Mobius C camera with the latest version of the lens. All in all, after trying different things with it and refocusing several times I am not completely pleased with the image quality when compared to my other Mobius lenses.
So I did basically the opposite of the above question. As an experiment, I installed a "B" lens in the "C" housing because I want to clarify whether the issues I am seeing are in the lens or the sensor. Aside from that I'm just curious to see what happens. About a year ago, I ordered a B module from Banggood that was defective. They were very good about promptly sending me a replacement after I sent screen shots demonstrating the bad sensor mine came with and this is why I just happen to have a spare B lens to do this experiment with. I will report back in a few days with the results.
BTW, it was not especially easy to screw the B lens into the C housing. It took a bit of coaxing to get it in far enough to focus properly. The threads in the FRP sensor housing have been very difficult to work with no matter which lens is used in it.
Edit: I just swapped lenses this morning so as of now I have no idea what results I will get. One of the things I plan to try is to see if there is any difference in the image if I use the "C" setting or the "B" setting in mSetup.
Will setting it to narrow FOV eliminate the slight out of focus sides?
Good question! I haven't had time to try that yet. Stay tuned!
So I assume you're running in Wide mode.(?) I think narrow mode works better for me but my A lens camera still seems a bit better at reading plates, etc. I have a sense that my lens is out of focus but it doesn't seem that way when I look at images, just a bit soft.
Certainly the narrow setting eliminates much of the out of focus areas from before but somehow there seems to often be a lack of critical sharpness in many scenes while at other times it looks better.
This is exactly how I feel about my C lens. I really can't complain because it looks good but somehow I feel it's just not as sharp as it should be. I still have to move my A lens camera to the front so I can get some clear camera to camera comparison shots.
Good to hear they are sending you a new lens. 🙂
So far, the whole transition to the FRP modules just seems like a giant step backwards for Mobius and I hope something gets done to rectify it.
Comment by Tom Frank at RCGroups within the last 24 hours...
"...new modules have been designed, and I will be posting about them shortly (in a day or two)".
@jokiin : can you tell us more about these other changes?
if only they had lens that is better than this oneI sent some screenshots to Banggood showing the left side out of focus issue with the original C lens installed and they are shipping me a replacement C module.
