Correct - there isn't Dash Board Glare in the rear.
AsTiffany said there isn't any instruction yet as it has not been released yet, I'd imagine installation would be stick rear cam on rear window, run supplied cable up to front of car and plug it into 512 gw.Many thanks for your respond , however I can't find any technical information about the new r-cam inside https://www.nextbase.co.uk/
I wonder how that will work on cars with opening rear doors? On my Rav, if the rcam is fixed to the glass, there's at least 4" of travel when I open the rear door, and that's assuming it's fixed in the top, offside corner - anywhere else would be even more tricky.
I was also wondering about the repeated flexing of the cable - I reckon I open and shut the rear door at least 1000 times a year - I do hope that the cable has been protected at the camera end, or the repeated flexing will find the weakest point, and possibly cause damage. I'm thinking that maybe the cable could somehow follow the same route as the wiring for the centre brake light etc, and pop out through the top of the door somewhere. All speculation of course... just thinking aloud really.
Hey tiffany could you add me to the list please.Fitted with the boot open it would give the cable maximum extension, putting little to no pressure on the cable through its use. The centre brake light sounds like a good idea.
