will be included in the next firmware, it's hard, but we will do it's hardWhy is the WDR not enabled? Or am I missing something?
had the first custom software but I have followed the above instructions to 1.1 custom but I get to http://192.168.8.1/Config/upgrade.cgi sasy waiting to connect then the waiting bit goes and it just sits there doing nothing so rebooted cam and it just carries on with the old 2000 orig software no custom 1.1Okay, Got Access and installed the FW.
This was ABSOLUTELY EASY to install.
For those people who are in doubt, I can just say do the upgrade!
I hat the latest original pittasoft FW v2.0000 (English) installed, and did it as instructed:
Put the custom550_1.0c.tar.gz file which downloaded into the root of the card and the upgrade.cgi file into the folder blackvue/config.
Then power on, connect to wifi and call the script in internet explorer with this URL:
It does not take long and you get a "done/please reboot"
After rebooting, all new modes for the setting are in the Webinterface AND in the Blackvue iPhone APP
Great work and worth a donation, even if you get it for free in the future...!
Thanks to the developers for this.
@alexsoll
maybe it makes sense, to also put a mode for 30 frames front cam and 15 (or even 7) for the back camera.
or maybe 30/15/7 individually selectable for each camera?
I can see it when I type http//192.168.8.1 so it must be connected okwlan connection to camera is present?
upgrade.cgi is present on the sd-card in the correct folder?
if yes, check after disabling antivirus or other stuff which might block the connection
Does anyone recomend a good micro SD card that has high write capibilty so i can increase the bitrate to as high as possible?
Sadly i cant get any Transend Ultimate in the UK.
First place i went.
it comes up with a list on the left hand side of the web page@rickyaswell
what exacty do you see if you enter the cam ip?
afaik the 1.1 fw is not zipped... it sould be rar archive...
you should describe the situation more precisely
