isaiah58
- Nov 11, 2020
- Germantown, MD 20874
I own a 2016 Subaru Impreza. I did not enable Parking Mode, I am avoiding using it until the U1000 shuts off with it disabled. I am not sure what you are asking about testing the OBD-II Cable. I purchased the one that Thinkware sells, through an authorized vendor. The one available for purchase on the Thinkware website, designed for the U1000. It is not hard to install. My car starts and everything works as before. I have the latest Firmware installed. Had to load it to a Micro SD card. I successfully linked the cam to my Hotspot, downloaded the Firmware, but the U1000 would not automatically update. Thinkware CS advised that this does happen, so to use the more reliable MSD method.
Anyways, it appears it is the logic in the U1000 that does not work with the recommended OBD Cable. It seems that the OBD Cable is feeding power to the U1000 with the ignition off, so doing what it was designed to do.
Edited to add: I am going to assume that I can just hit the Power Button instead of pulling the power cable out, yes? This should turn the U1000 Off and not draw any power?
