GPak
That's why I mentioned it: German cars are known for their delayed ACC.
A 5-minute ACC delay is probably the best case, more often it's around 10-15 minutes or so.
This means the Ecoflow will draw power from the car's battery rather than the alternator, which isn't good.
Hopefully, you can find an ACC with instant-cutoff, but if you can't find one, there's another option.
Instead of an ACC-activated relay, you can use a voltage-sensing relay (VSR) linked here:
Voltage Sensing Relay
The only caveat here is that some modern alternators may not always output above 13.2 V, depending on the engine and/or battery management system.
A test is the only way to find out.
