It will be for both. A119S will be ready first.Unable to find the new version on the VIOFO website - is A119S V2 just the A119s or the A119 also ???
Sweeeet, 30 biscuits is fine............. While your busy in HK, could you get someone else to organize my purchase quicker ?
My A119 just died because of power error or whatever. Screen blinks, restarts. I use direct power from charger to camera without GPS mount.
Never again Viofo product.
Try using a different USB charger and/or cable. Be sure to try both of the Viofo cables that came with the camera. Your issue is a sign of not enough power getting to the camera.My A119 just died because of power error or whatever. Screen blinks, restarts. I use direct power from charger to camera without GPS mount.
You're confusing voltage and amperage. And it's not so much a power bank versus a cigarette adapter, as the quality of the adapter. And remember that all USB ports are not created equal. They all provide 5 volts, because if it were higher or lower, it would fry stuff. Most car USB ports (built into a stereo or from the factory) can't power a dashcam because they can't provide enough amps. Power banks and wall phone chargers can often supply 2-3 amps, but a computer or car stereo USB port only supplies 0.5 amps in most cases. The camera needs about 1 amp at 5v. That's why we always tell people to use the adapter that came with the camera, so we know it can provide enough amps.it's the voltage + cable AWG. my both camera's screens flicker when powered from car's electricity and don't flicker when powered from power banks. power banks provide higher voltage. I use 24/28 AWG 15ft cables, couldn't find 22 AWG 15ft.
Obviously didn't fix itself permanently, but all the plugging and unplugging may have bent it in a way that now it's making better contact... For the moment. If that's the problem then the "fix" won't last long.
