On page one in the video at 1min 6sec I just wondered if the numbers counting down at the traffic lights indicated the seconds left before the lights changed red again. If so thats very driver friendly it would be nice to see other countries adopting the same system. Of course this might mean a drop in revenue with borderline red light tickets, I wont be holding my breath. Ipol![]()
@ jokiin thanks for the swift response yes its a nice touch more to do with road safety than the usual mentality of hitting the motorists pockets. Ipol![]()
You have to read about how the electric things work. It's hard for med to explain in english. I can't the English terminology. A device that use the power determins how much it need. The power supply only deliver the Power it is asked for. So that means that the power supply only need to be able to deliver the current (A) that the device need. The power supply can never deliver more current (A) than what the device asks for & of cource not more than what it is specified for.
So you can without any danger use a Power supply that can deliver a maximum of 2.1A for a device that only uses 0.5A. But you can not do vice versa, use a power supply that delivers 0.5A together with a device that need 2.1A. Then the PS either will be overloaded, shutoff or explode like in the movies.
http://en.wikipedia.org/wiki/Ohm's_law
U=I*R
P=U*I
U=Volt, I=Ampere, R=Resistance, P=
It didnt seem to glitch any before quitting, the video clips appeared as if i had shut the car off.Check your memory card, if it glitches and recording stops it will power off a few minutes later
This model can be a bit fussy with memory cards as to which models it works with
I will try the original cable for a while. I switched it out because the original cable interfered with my FM, and i didnt realize the cables had such a big difference in output until nowPower can also be an issue, try it with the supplied power adapter and see how it goes
To reduce interference, you can use the ferrite filter such as - http://www.solar-electric.com/nosufefi.html on the original cable. You need to install a two filter on the cable.I switched it out because the original cable interfered with my FM
The cable i switched to has no issues with interference, i just assumed the original was a dud. Ill mess with cables for a bit and see if i can get the camera to work right before i worry about the interferenceTo reduce interference, you can use the ferrite filter such as - http://www.solar-electric.com/nosufefi.html on the original cable. You need to install a two filter on the cable.
I will make the addition of: more about this here http://computer.howstuffworks.com/question352.htm
Very often the power supply for dashcam makes another noname factory
for a low price
Yeah I understand,I wanted to point only about the original cableThe cable i switched to has no issues with interference, i just assumed the original was a dud. Ill mess with cables for a bit and see if i can get the camera to work right before i worry about the interference
Thanks for the info.My cam had a problem of switching off and not restarting. To overcome this I have left the screen on. Boots up when powered up and shuts down as programmed now.
