Latest and stable firmware, version number is "GIT2_V1.4_20160324", released on 24th March 2016.
https://dl.dropboxusercontent.com/u/22493212/GIT2FW_20160324.zip (
Please read the upgrade instructions first before you upgrade.)
Change Log:
- Added: 4:3 video mode, 1440*1080 60fps video resolution.
- Added: Support remote shutter through HDMI port with special cable
- Added: Video recording pause and resume via Menu button
- Added: Video Time Lapse: 1F/2Sec
- Added: Fast-forward clips during playback through a list of 1X, 2X, 4X, 8X via menu button
- Added: Video Bitrate options for below modes: 1080P 60fps, 1440P 30fps, 1296P 30fps, 2160P 24fps, 1080P 30fps;
- Added: Support for sensor calibration (fixing hot pixels) by user.
- Added: Video shutter speed option: Auto, 1/30s, 1/60s, 1/120s, 1/240s, only works while ISO is not set for Auto;
- Added: Lock Actual Recording via Menu button
- Added: Photo time lapse: 0.5s option
- Added: Polish and Dutch language, improved Portugal, French, Spanish, Italian, German translation
- Improved: Delete the firmware after upgrade new firmware.
- Improved: Changed Custom AWB adjustment range from 0-9 to 0-19
- Improved: Soft and Strong sharpness, close to the normal option
- Improved: Front red LED will be blinking for last 3 seconds while taking self-timer photo (When you see the red Led blinking, it is time to smile)
- Improved: No Wi-Fi info displayed while OSD off;
- Improved: Do not auto start recording if powered on by battery on car DVR mode;
- Improved: Removed 1s overlap;
- Improved: Support real 240fps;
- Improved: Update the web camera name to Git2 instead of DEMO1
- Improved: Display shutter speed option on screen on photo mode
- Improved: LED blinking as normal recording and update the video mode icon on video time lapse mode
- Fixed: No audio while playback on TV via HDMI
- Fixed: The date is not shown properly in the preview mode
- Fixed: Quick start capture is not working while connected with external charger.
- Fixed: Unmute Recording Audio issue by menu button
- Fixed: Video shaking on 720P 30fps mode with Gyro on
- Fixed: Camera frozen while taking 16MP in 10 sequences burst mode
- Changed: Top and Front LED blinking on Car DVR mode
Upgrade Instructions for V1.4:
- If you camera firmware version is V1.2 or earlier, please upgrade the loader GIT2LD.bin(include in Loader_for_old_firmwares.zip) first.
- If you have already installed the V1.3 firmware, no necessary to upgrade the loader, please ignore the #3--#6 steps.
- From V1.4 firmware, the firmware will be automatically deleted from Micro SD card after upgrade completed.
- Use max. 32GB card formatted by camera or on computer as FAT32
- Insert card in camera and connect it to computer using USB cable
- Copy just the GIT2LD.bin on the root of the card
- After GIT2LD.bin is copied to the card disconnect the camera from computer
- Reconnect the camera to your computer and wait few seconds until you can chose Mass Storage from camera menu
- Delete GIT2LD.bin from the card using your PC and
- Copy the GIT2FW.bin file on the root of the card
- Reconnect the camera to your computer and wait more seconds until you can chose Mass Storage from camera menu, the front green LED and back red LED will be blinking while upgrading.
Now you can disconnect the camera from PC and enjoy new GitUp implementations
V1.3 released, version number is "GIT2_V1.3_20160130", released on 30th Jan 2016.
Download link:
http://www.gitup.com/support/firmware/git2/20160130/GIT2FW.zip
Change Log:
- 1. Added: 4:3 video mode, 1920*1440 30fps video resolution.
- 2. Added: Menu selection of remote control operation modes: “Standard”, “Quick Shoot”.
- 3. Added: Self timer delay for photo mode, menu selection from: 3S, 5S, 10S, 15S, 30S.
- 4. Added: Menu selection of USB modes: Web camera, Mass storage.
- 5. Added: Czech language.
- 6. Improved: Screen-saver operation during photo time lapse.
- 7. Improved: Support for 64GB and 128GB cards, using FAT32 format.
- 8. Improved: Battery indicator.
- 9. Improved: Recorded audio volume adjustment.
- 10. Improved: Back red LED and front green LED will blink while upgrading with new firmware.
- 11. Improved: Russian language translation.
- 12. Improved: Video files now limited to 4GB file size instead of 15 minutes file time.
- 13. Fixed: AE lock and AWB lock during loop recording.
- 14. Fixed: Image shake issue on 720P video mode while Gyro stabilization enabled.
- 15. Fixed: Custom shutter speed issues - double exposure time and low ISO image brighter than higher ISO
Upgrade Instructions for V1.3:
If you camera firmware version is V1.2 or earlier, please upgrade the loader GIT2LD.bin first.
- 1. Use max. 32GB card formatted by camera or on computer as FAT32
- 2. Insert card in camera and connect it to computer using USB cable
- 3. Copy just the GIT2LD.bin on the root of the card
- 4. After GIT2LD.bin is copied to the card disconnect the camera from computer
- 5. Reconnect the camera to your computer and wait few seconds until you can chose Mass Storage from camera menu
- 6. Delete GIT2LD.bin from the card using your PC and copy just the GIT2FW.bin file on the root of the card
- 7. Reconnect the camera to your computer and wait more seconds until you can chose Mass Storage from camera menu, the front green LED and back red LED will be blinking while upgrading.
- 8. Delete GIT2FW.bin
- 9. Now you can disconnect the camera from PC and enjoy new GitUp implementations.
New V1.2 Version released at 2015.12.24.
http://www.gitup.com/support/firmware/git2/20151224/GIT2FW.zip
version:GIT2_V1.2_20151224
Change log:
1. Added: Shutter Speed
- a) 1/30 Sec.
- b) 2 Sec.
- c) 5 Sec.
- d) 10 Sec.
- e) 15 Sec.
- f) 20 Sec.
- g) 1 Min
2. Improved: Battery charging
- a) OFF Red LED and ON Green LED then camera fully charged
- b) Disable screen backlight after 1 minute while charging but enable backlight again if user press any button
3. Added: Configurable function for menu button while recording:Gyro Image Stabilization
4. Added: Control Led Status
- a) All LED On (Turn on all LED)
- b) All LED Off (Turn off all LED)
- c) Front LED Off (Turn off front LED)
- d) Side LED Off (Turn off top LED and Wi-Fi LED)
- e) Back LED On (Only turn on the back LED)
5. Improved: Gyro icon color becoming Orange while moving
6. Added: Options for Photo Time lapse
- a) 5 mins
- b) 10 mins
- c) 30 mins
7. Added: 2304*1296P 30fps for video resolution
8. Improved: G-sensor sensitivity
9. Improved: Motion Detection sensitivity
10. Added: On/Off option for custom text stamp
11. Improved: Auto enable the loop recording while G-sensor enabled
12. Added: ISO option for video and photo settings
- a) ISO 50
- b) ISO 100
- c) ISO 200
- d) ISO 400
- e) ISO 800
- f) ISO 1600
13. Updated: Menu string and icon
New V1.1 firmware released.
http://www.gitup.com/support/firmware/git2/20151201/GIT2FW.zip
Change log:
1. Added: Configurable function for menu button while recording with options of:
a) exposure lock,
b) white balance lock,
c) exposure lock and white balance lock
d) microphone mute/unmute
2. Added: Metering option for Video and Photo
a) Centre
b) Average
c) Spot
3. Added: Color option for Video and Photo
a) Normal
b) Black & White
c) Sepia
d) VIVID
4. Added: Auto Power Off option:
a) 15 minutes
b) 30 minutes
c) 60 minutes
5. Added: Video Time Lapse
a) 1F/5Sec
b) 1F/10Sec
c) 1F/30Sec
d) 1F/5Min
e) 1F/10Min
6. Added: RAW Photo
7. Improved: LCD Brightness
8. Improved: Auto White Balance
9. Improved: Gyro Image Stabilisation
10. Updated: Menu string and icon
11. Updated: Default settings
a) Screen Auto Sleep: 1 Minute
b) Auto Power Off: 3 Minutes
12. Fixed: Black screen while power on
13. Added: Volume adjust.
