@gitup here are my findings with v1.4. and some requests. may be for v1.5?
video mode:
- where do I enter custom text, when option is enabled?
- 10 sec timelapse and 5 sec snapshot enabled: front yellow led is turned on every 20 mins for about 10 min
- 10 sec timelapse and 5 sec snapshot enabled: timestamp only appears on every 10th picture
- request: option to auto adjust light settings during timelapse. especially during sunset/sunrise this would be great. best option would be to have
the last 3 pictures histogram analyse for the best setting in order to avoid flickering in the timelapse video. but it must be an option to to enable disable.
- request: instead of high, medium low display the reals BPS values
photo mode:
- request: rename of timelapse to interval ( as it is no real timelapse)
- no display of active interval mode when taking a picture
- no custom text option
- request: shutter speed 1/100 and 1/60
play video:
- request: move timer below video
play slideshow
- how does it work?
general:
- problem with adapter in car. manual plugin in and out does not affect the recoding (ok)
but when the car is started the camera turns off by itself. (not ok) car mode was not enabled.
- resorting of menus. some often used options are at the end, while unimportant options are in the front
- request: option to set the max ISO level in auto mode (eg max 400 ISO)
- sometimes mode button does not function
- request: option to go back in playback mode
- cam becomes not responsive after wifi is disabled (need to remove battery)
- not possible to connect to final cam
- not possible to connect to RC (was possible with v1.3)
