Loserkid
- Dec 23, 2015
- Spain
- GitUp Git2, GoPro Hero 4 Silver
Im sad, there is no 50FPS Option in FW1.5beta. 🙁There is beta 1.5 out
A new Beta firmware from Gitup is released. Remember this is just a Beta version. 🙂
Glad to share the V1.5 beta version for Git2.
Download link: https://dl.dropboxusercontent.com/u/22493212/GIT2FW--V1.5B--0422.7z
Change log:
1. Added: 4:3 aspect ratio for 2880x2160P 24fps mode
2. Added: Pause icon on screen while recording is paused
3. Added: Strong color option in video mode (lower saturation compared to Vivid option)
4. Added: New OSD mode, only show video mode and recording dot
5. Fixed: 2160P 24fps video not smooth
6. Fixed: Camera powered off while the file reached 4GB in quick capture mode
7. Fixed: Camera restarting issue in quick capture mode, plug the charger while recording, then stop recording and unplug the charger after the camera powered off
8. Fixed: Wrong EXIF info
9. Improved: Stop recording in middle level for remote shutter.
10. Improved: Web camera resolution is upgraded to 1920*1440
11. Improved: Wi-Fi stream resolution is upgraded to 1280x960 if enable the Wi-Fi from 1440P or 1080P 4:3 mode.
Sent from my SM-A800F using Tapatalk
I have this idea last year, now we are doing some research and testing.
yeah, i thought i had seen @gitup post it themselves, but now i can't find it.
yeah, that's what I thought.Or a Dashcam one button mode and an action cam mode that has all the parameters all setup as you like them to switch between the two on demand.
For that particular video, the problem is that there is so much moving so fast in all directions that YT cant crush all the information into it's fixed bitrate. Might do better if the video was upscaled to 4K before upload, the upload shouldn't be any bigger since there is no more information, but YT will allocate a higher fixed bitrate for 4K video so will be able to store more movement data.I don't know what youtube does, but when i watch videos recorded with the Git2, quality is lower than other videos in general. A lot of pixelation, jerky movement.
I guess is because of the container, format, bitrate or others things. But in general the Git2 videos seems to be very punished (degraded) in the upload process. They lose too much.
I'm not an expert, i just guess that currently the files from the Git2 do not respond well to youtube's reencoding.
Perhaps the key to avoid this is to have a file that is specially encoded to be re encoded by youtube. (It's not what i need/ask for though, i'm just guessing)
What is this?8. Added: Car DVR metering for dash cam usage
Metering option like dash cam used.What is this?
