Latest and stable firmware, version number is "GIT2_V1.6_20161028", released on 28th Oct 2016.
http://www.gitup.com/support/firmware/git2/20161028/Git2_FW_V1.6.zip
Change log:
1. Added: Support Image Rotation
2. Added: Update settings from configuration file
3. Added: Photo Shutter Speed Options: 1/2000sec, 1/1000sec, 1/500sec, 1/250sec, 1/125sec
4. Added: New Wi-Fi command for time-lapse, self-timer, etc.
5. Added: Front LED On only option
6. Added: Support mode/menu button to enable quick function
7. Added: Support turn off screen via mode/menu button
8. Improved: Default setting time is same as firmware released time.
9. Improved: No frame drop in 1080P 60fps at low light condition.
10. Improved: Update IQ.
Latest and stable firmware, version number is "GIT2_V1.5_20160621", released on 21th June 2016.
Change log:
- 1. Added: 4:3 aspect ratio for 2880x2160P 24fps mode
- 2. Added: Wi-Fi mode option: AP, Station(Client)
- 3. Added: Support customize boot logo and power off logo
- 4. Added: Wi-Fi Auto-start option: On, Off
- 5. Added: Pause icon on screen while recording is paused
- 6. Added: Colorful color option in video and photo mode (lower saturation compared to Vivid option)
- 7. Added: 15s option for screensaver;
- 8. Added: Car DVR metering for dash cam usage
- 9. Added: New OSD mode, only show video mode and recording dot
- 10. Added: Video shutter speed 1/48s
- 11. Added: Contrast option for video and photo: Normal, High, Low
- 12. Fixed: 2160P 24fps video not smooth
- 13. Fixed: Camera powered off while the file reached 4GB in quick capture mode
- 14. Fixed: Camera restarting issue in quick capture mode, plug the charger while recording, then stop recording and unplug the charger after the camera powered off
- 15. Fixed: Wrong EXIF info
- 16. Fixed: Video ZOOM issue while AV out in narrow mode
- 17. Fixed: No beep while taking photo with FPV cable connected
- 18. Improved: Stop recording in middle level for remote shutter.
- 19. Improved: Once press shutter button to start/stop recording while in screensaver mode
- 20. Improved: Web camera resolution is upgraded to 1920*1440
- 21. Improved: Wi-Fi stream resolution is upgraded to 1280x960 if enable the Wi-Fi from 1440P or 1080P 4:3 mode
- 22. Improved: No OSD info while playback on TV through HDMI if OSD option is turned off
- 23. Improved: Support output RTSP steam in 2160P, 720P 120fps and VGA 240FPS mode
- 24. Improved: Support power on camera to start recording or take photo in charging mode via HDMI shutter trigger
- 25. Improved: Top and back LED blink once while taking photo
- 26. Improved: Spanish, Czech, Russian, Polish language
Download link:
http://www.gitup.com/support/firmware/git2/20160621/GIT2FW_20160621.zip
Latest and stable firmware, version number is "GIT2_V1.4_20160324", released on 24th March 2016.
https://dl.dropboxusercontent.com/u/22493212/GIT2FW_20160324.zip (
Please read the upgrade instructions first before you upgrade.)
Change Log:
- Added: 4:3 video mode, 1440*1080 60fps video resolution.
- Added: Support remote shutter through HDMI port with special cable
- Added: Video recording pause and resume via Menu button
- Added: Video Time Lapse: 1F/2Sec
- Added: Fast-forward clips during playback through a list of 1X, 2X, 4X, 8X via menu button
- Added: Video Bitrate options for below modes: 1080P 60fps, 1440P 30fps, 1296P 30fps, 2160P 24fps, 1080P 30fps;
- Added: Support for sensor calibration (fixing hot pixels) by user.
- Added: Video shutter speed option: Auto, 1/30s, 1/60s, 1/120s, 1/240s, only works while ISO is not set for Auto;
- Added: Lock Actual Recording via Menu button
- Added: Photo time lapse: 0.5s option
- Added: Polish and Dutch language, improved Portugal, French, Spanish, Italian, German translation
- Improved: Delete the firmware after upgrade new firmware.
- Improved: Changed Custom AWB adjustment range from 0-9 to 0-19
- Improved: Soft and Strong sharpness, close to the normal option
- Improved: Front red LED will be blinking for last 3 seconds while taking self-timer photo (When you see the red Led blinking, it is time to smile)
- Improved: No Wi-Fi info displayed while OSD off;
- Improved: Do not auto start recording if powered on by battery on car DVR mode;
- Improved: Removed 1s overlap;
- Improved: Support real 240fps;
- Improved: Update the web camera name to Git2 instead of DEMO1
- Improved: Display shutter speed option on screen on photo mode
- Improved: LED blinking as normal recording and update the video mode icon on video time lapse mode
- Fixed: No audio while playback on TV via HDMI
- Fixed: The date is not shown properly in the preview mode
- Fixed: Quick start capture is not working while connected with external charger.
- Fixed: Unmute Recording Audio issue by menu button
- Fixed: Video shaking on 720P 30fps mode with Gyro on
- Fixed: Camera frozen while taking 16MP in 10 sequences burst mode
- Changed: Top and Front LED blinking on Car DVR mode
Upgrade Instructions for V1.4:
- If you camera firmware version is V1.2 or earlier, please upgrade the loader GIT2LD.bin(include in Loader_for_old_firmwares.zip) first.
- If you have already installed the V1.3 firmware, no necessary to upgrade the loader, please ignore the #3--#6 steps.
- From V1.4 firmware, the firmware will be automatically deleted from Micro SD card after upgrade completed.
- Use max. 32GB card formatted by camera or on computer as FAT32
- Insert card in camera and connect it to computer using USB cable
- Copy just the GIT2LD.bin on the root of the card
- After GIT2LD.bin is copied to the card disconnect the camera from computer
- Reconnect the camera to your computer and wait few seconds until you can chose Mass Storage from camera menu
- Delete GIT2LD.bin from the card using your PC and
- Copy the GIT2FW.bin file on the root of the card
- Reconnect the camera to your computer and wait more seconds until you can chose Mass Storage from camera menu, the front green LED and back red LED will be blinking while upgrading.
Now you can disconnect the camera from PC and enjoy new GitUp implementations
V1.3 released, version number is "GIT2_V1.3_20160130", released on 30th Jan 2016.
Download link:
http://www.gitup.com/support/firmware/git2/20160130/GIT2FW.zip
Change Log:
- 1. Added: 4:3 video mode, 1920*1440 30fps video resolution.
- 2. Added: Menu selection of remote control operation modes: “Standard”, “Quick Shoot”.
- 3. Added: Self timer delay for photo mode, menu selection from: 3S, 5S, 10S, 15S, 30S.
- 4. Added: Menu selection of USB modes: Web camera, Mass storage.
- 5. Added: Czech language.
- 6. Improved: Screen-saver operation during photo time lapse.
- 7. Improved: Support for 64GB and 128GB cards, using FAT32 format.
- 8. Improved: Battery indicator.
- 9. Improved: Recorded audio volume adjustment.
- 10. Improved: Back red LED and front green LED will blink while upgrading with new firmware.
- 11. Improved: Russian language translation.
- 12. Improved: Video files now limited to 4GB file size instead of 15 minutes file time.
- 13. Fixed: AE lock and AWB lock during loop recording.
- 14. Fixed: Image shake issue on 720P video mode while Gyro stabilization enabled.
- 15. Fixed: Custom shutter speed issues - double exposure time and low ISO image brighter than higher ISO
