go back a page or two - i and a couple others had that issue too. try it without a PC. copy the LD file on the sd card by itself, put card in camera, power on camera. wait for lights to stop flashing and/or turn off completely for at least 30 seconds. take out SD card. erase LD file, copy the actual firmware bin file on the card, then put the card in the camera, power on, wait for lights to stop flashing (about a minute from what i remember) and turn off. then remove SD card, power on camera again and you should be good. your preferences will be reset so be sure to go back into system and change stuff like 50/60hz, pal/ntsc, and other options you want. only thing it keeps is time/date.Um huge problem! I just tried to update my gitup 2 and now the camera wont turn on? I tried to put the .bin file on my 32gb card, ugrading from v1.2, turned on the camera with card in camera and .bin file in root, green light came on was blinking, stayed green wouldnt turn off green accidently hit the power button on front moving the camera around to see if other lights were on, now camera will not turn back on? Nothing, nada, zero, zilch, no light no nothing? What do i do, im freaking out.
Nice GitUp images, clean windshield and car!Test 4:3
You just need check the version number, the latest is V1.3.Is there anything else i have to do to make sure the upgrade was successful?
please try doing what i said in my post above. do not connect camera to computer.I have the same problem than others, camera is unusable after upgrade 1.3. Doesn´t works, doesnt turn on and battery is 100x100 charged? It´s possible to do downgrade to v 1.2. i´m so angry. i have tested upgrade with pc, without pc and i am desperate
What Drifter said above is very important in trying to figure out the issue. Some of the questions that should be asked/answered 1) did I follow the instructions and flash each file individually? 2) did I use an SD card that was less than 32gb and formatted correctly? 3) did i connect the camera to pc or not? Etc...Before people get on the bandwagon of condeming gitup for having a bad firmware, it would be nice to know if the people who are having problems followed the upgrade steps exactly or did they skip something like the ld file?
In my case i disconnected the camera after putting the LD file on the camera. Which was not part of the instructions. :/Before people get on the bandwagon of condeming gitup for having a bad firmware, it would be nice to know if the people who are having problems followed the upgrade steps exactly or did they skip something like the ld file?
But is clear that you need to disconnect and reconnect the camera because you will not look on PC Monitor how nice is sitting the bin file into the root of the Micro SDCard.In my case i disconnected the camera after putting the LD file on the camera. Which was not part of the instructions. :/
