GhostMaster
- Feb 24, 2016
- Portugal
Yes I know but this camera is amazing and at 95$ shipped it's a steal. Crazy deal... Mine was 140$
You just need short press on RC remote. When it show light on RC, means it still have power, if the light is not so brighter as before, means less power maybe no enough power.3. My RC remote is either acting weird, or I'm not using it correctly. When I press the button, like to toggle WiFi, do I need to keep the button down for a while? Also when I press any of the 4 buttons, the green LED flashes once, then the red LED pulses for around 2secs. Am I maybe out of battery?
Thanks!
PS apologies, I should have posted this in the support thread...
2. For photo FOV, you need to crop the image in your photo editor to give whatever FOV, width, height, zoom factor and aspect ratio you desire. You don't loose any quality doing it this way since that is what the camera would do if it did have the option. Personally I like an optical zoom, but then it wouldn't be an action camera.2. Is there a way to switch between wide and narrow fov for shooting photos?
And in the latest beta that works great too.2x and 4x slow motion work great with or without Gyro. However, 8x is still very choppy with or without gyro. Can this be fixed next firmware?
I got it functional again. If you do this where its not connected to the computer, the proper sequence is:
1) Copy just the GIT2LD.bin on the root of the card
2) Put card in camera, turn it on. Green light will light on front, red light will light in back, LCD will be dark. Wait one minute. Turn camera off (its confusing, as those lights just stay on and nothing happens)
3) Take card out, put it in adapter and back into your PC. Delete the LD.bin file from the root, and copy the GIT2FW.bin to the root of the card.
4) Put card back into camera. Turn camera on. Front lights and back lights will blink and update will take about a minute. When lights stop blinking, remove card, delete the .BIN file from the card on your PC, put back into camera, and now you can turn camera on and it will function
Actually, it's the other way around!wild guess but it might be play to indicate videos, film to indicate photos
The film indicates a film (movie) and the play is for photos, I think because it lets you play the slideshow from the menu button instead of showing the movie.
The play mode on the Gitup cameras isn't the easiest to use, only 3 buttons on the camera works nicely for recording but it is a bit limiting for playback control and navigation.I did say wild guess, haven't had the benefit of actually seeing one of these
with any of these types of things pressing a couple of buttons generally lets you work it out anyway
But since it has WiFi it's not that big a deal. 🙂The play mode on the Gitup cameras isn't the easiest to use, only 3 buttons on the camera works nicely for recording but it is a bit limiting for playback control and navigation.
Hi, My Git2 appears to be dead, i.e. it will not turn on and shows no sign of life either with fully charged batteries or connected to a computer or power supply. It had been working fine with V1.2 loaded, but there has been no sign of life since I attempted the upgrade to V1.3. I followed every step to the letter on the Gitup website. I have since tried the advice to rename the loader name from GIT2LD.bin to LDNH2.bin, but still nothing happens when I plug the camera into the computer, as instructed. Please would someone advise me what to do to breath life back into my camera. Thank you.also normally even for a "dead"(no response) camera
go back a few pages in this thread - i had that problem myself. i solved it by NOT connecting to the computer, but also doing a few steps in particular order.Hi, My Git2 appears to be dead, i.e. it will not turn on and shows no sign of life either with fully charged batteries or connected to a computer or power supply. It had been working fine with V1.2 loaded, but there has been no sign of life since I attempted the upgrade to V1.3. I followed every step to the letter on the Gitup website. I have since tried the advice to rename the loader name from GIT2LD.bin to LDNH2.bin, but still nothing happens when I plug the camera into the computer, as instructed. Please would someone advise me what to do to breath life back into my camera. Thank you.
Thank you, Gibson99, I tried your method again and it worked this time. As you say, "Phew!" However, I have another problem that I have not read about: the shutter/select button and its adjacent light do not work. At first (before I had the firmware upgrade issue) the button became intermittent and the red light flickered, then it became totally unresponsive. I can start/stop recording using the remote, but have no access to the select function to adjust settings. It sounds to me like a hardware issue. Anyone any ideas?go back a few pages in this thread - i had that problem myself. i solved it by NOT connecting to the computer, but also doing a few steps in particular order.
Hello, please can you send me the firmware? I want try him. Thank youOf course no problem, we'd like have more users to test the beta firmware first before official release, we are still working on that, need add the bitrate options.
Because for dashcam usage, no necessary to use so high bit-rate.
Pm me with the beta firmware, I'm happy to help testing.Of course no problem, we'd like have more users to test the beta firmware first before official release, we are still working on that, need add the bitrate options.
