What config you used To get this pics?Took a few photos with the Git2 today:
Not bad for a video camera![]()
They were taken with a prototype Git2, before the colour balance was properly sorted. They are all taken in photo mode with automatic ISO/exposure (the manual settings didn't exist then) and probably soft sharpening. I may have used the EV+WB lock to get some of those exposures, the Gitup remote control and monopod for the leaves over the water, a close focus filter for the dragonfly and flower (background out of focus), and Paint Shop Pro to crop/resize/adjust colour/sharpen. There was no raw mode then so these are all jpg images.What config you used To get this pics?
This takes a lifetime of practice, experimentation and reading!Im new at the action camera world, actually I'm new in the camera world in general, do you know if there is guidance on how to use the GIT2 so I can use it like a real pro haha, yeah I know Im asking for a miracle, but If you know something about it or someone knows something about it please tell me!!!
Is this (£15.00) the real price?
If you are using 60fps then possibly it is dropping to 30fps due to low light conditions?I am using verified class 10 u3 micro sd cards (rated at 90mb/s) when recording but I still get a frame or two of skipping when using the 10 minute loop mode. Is this normal? Can it be fixed?
No more fps dropping in 1.6 firmware.If you are using 60fps then possibly it is dropping to 30fps due to low light conditions?
Also, could it be the playback that is the issue rather than the recording? You can use the camera to play through HDMI to check.
It is unlikely to be due to the card, it doesn't need anywhere near 90mb/s, a plain class 10 will do for the normal bitrate setting.
But frame skipping, I suppose, can be happened due to the h.264 coding algorithm. The h.264 have key frames that are placed with some interval in file. So, if camera do the cutting the video not in a key frame position then it might be possible to loose some video frames up to the nearest next I-keyframe. I suppose...
So does it only happen at the end of each file?That is an interesting possibility. Since it was 24fps it would be more exaggerated if there was a keyframe mismatch. @gitup Is that something that could be accounted for in a firmware update?
If you are going to blatantly promote a certain manufacturer's product, at least have a little discretion, and also mark yourself as a retailer or manufacturer. Please contact @DashCamMan for help with that.As we heard from SJCAM factory, SJCAM new models are coming, looks cool!
This statement in this part of the forum confirmed me to have made the right decision.As we heard from SJCAM factory, SJCAM new models are coming, looks cool!
No necessary to act as a normal user, just tell us you are from SJCAM.As we heard from SJCAM factory, SJCAM new models are coming, looks cool!
I haven't forgotten the XTACAM first post on RCGroups.
