D
Deleted member 24437
Guest
What is the bitrate in Git up's 2k please ?If you want better than the 17Mbps then you should use the 60fps mode which gives you 28Mbps.
The only advantage you might notice from going above the 17 at 30fps is that you may get better detail with a lot of high speed movement in the image, but that is what the 60fps mode is for.
