Mtz
- Nov 15, 2012
- Nice place
- Romania
- Viofo A229 Pro TeleQuad (the best dashcam in the world!)
It is mainly because the pixels on the Gi1 are about 8x the size of the pixels on the Git2, they are much better at detecting low light levels. That is not going to be improved any time soon.The Git1 video all the colors of the brush, grass etc were very vibrant and defined. The Git2 video the colors were plain and boring looking.
Now I am thinking to sell my GitUp as Hero 5 because it have more features than Hero 4 so it can be considered the new version of Hero series.
enjoy,
Mtz
This is right address rtsp://192.168.xxx.yyy no need for portI'm doing something wrong.
VLC player path: RTSP://192.168.0.206:554
I think there is lack of pointing stream file
Yes now it's working thx. Can I improve the quality of stream (now I got 640x360)?This is right address rtsp://192.168.xxx.yyy no need for port
Ok now streaming works okUse one of the 4:3 resolutions.
The images are real. Note that the seller is Chinese, you will not be paying for good service, but the Git2 does not have many problems anyway.I'd like to buy a Git2. How I can I recognize fake from genuine?
Is this a genuine?
http://www.ebay.de/itm/Ultra-2K-144...718248?hash=item4af9a1eb68:g:n54AAOSwG-1WyuCM
Try a different cable...Please help.
I have strange issue with my GitUp2. After connecting my cam to PC via USB cable I dont have any prompt message to choose. Camera is just charging. (tested on 3 different PC, including MAC) How can I fix it?
In the system setting menu, did you choose USB mode: prompt?Please help.
Yes 100% sure. Tried 2 different cables. Will try with another one later.In the system setting menu, did you choose USB mode: prompt?
I think, once, I tried to use a USB cable that came with a non-git 2 battery/ charger combo. and had a similar problem. The two cables looked identical!Yes 100% sure. Tried 2 different cables. Will try with another one later.
Also my cam is reseting System Date quite often. Does system date reset everytime I remove battery?
Not all USB cables are the same. Some, made for chargers, don't have the data wires inside, so it's cheaper to make. That's probably the issue here.I think, once, I tried to use a USB cable that came with a non-git 2 battery/ charger combo. and had a similar problem. The two cables looked identical!
Good Luck!
The Git2 170 degrees is not sync. with other 3 at some moments.
For me is strange that Git1 is so dark during day in your weather conditions.
The best colors I see are for 94 degrees lens.
enjoy,
Mtz
Pleas take note that the 72 and the 94 lenses are manually adjusted by me, while the 170 one is stock from GitUp.I liked more the 170º lens on the Git2. It looks sharper and the scene is better exposed.
