Rodrigo Emedy
- Apr 14, 2015
- Brazil
Nope... Cygwin x86 didn't work either.. boot loop remains...
I have the Q3H
Why not just run time lapse ????
1st menu option , 0.5s should give you 2FPS ...
Memory card should last for quite some time ...
Or maybe 1s 1FPS , 60 frames per minute , or 3600FP hour ...
Did you actually put "run" in the command? I'm not in front of my pc at the moment, so can't check.I fixed this problem. I was making a mistake, and just creating the Phoenix image from the same old file at the goprawn.img.dump folder..
But now, making everything right, I got the boot loop. I'm using Cygwin64 running the command:
run mksquashfs.exe squashfs-root 2-system.img -comp xz -Xbcj x86 -noappend -no-recovery -root-owned
And I'm using the mksquashfs.exe that you compiled. π
I'll try the Cygwin 32bit.. Do I need to install any specific Cygwin package, at Cygwin's installation?
This version of mksquashfs.exe is not compatible with the running version of Windows. Check the computer system information to determine if you need an x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software manufacturer.
I think some of the H9 Cams do 10FPS in 4k .. not sure about MB/s ... ( Reviewers don't give that information )
You can either copy both mksquashfs.exe & unsquashfs.exe to /usr/local/bin or run the command like this (make sure you're in the same directory where the mksquashfs.exe located):-@kizwan .. I'm may be doing something wrong with the Cygwin.. you mentioned that you didn't use the "run" before the .exe.. if I just paste your command line, it gives me "
-bash: mksquashfs.exe: command not found".. but if I add the "run" before the mksquashfs.exe, it runs and build the 2-system.img file, BUT without all the verbose text I see on your screen capture of Cygwin.
I already tried to run it, on specific drive ie.:
cd g:
cd squashfs-tools
...and at its home directory at c:\cygwin64\home\Rodrigo
I installed both x86 and x64 versions at their defaults options.. I saw a bunch of addons to install, but didn't choose any of it.
./mksquashfs.exe squashfs-root 2-system.img -comp xz -Xbcj x86 -noappend -no-recovery -root-owned
You can see that I added "./" (no space) in front of the command. This basically calling the command that is located in the same directory.Code:./mksquashfs.exe squashfs-root 2-system.img -comp xz -Xbcj x86 -noappend -no-recovery -root-owned
cd /cygdrive/c/Users/myuser/Downloads/4kbackup
cygstart ./unfex.bat
/usr/local/bin/unsquashfs.exe -f UNFEX/2-system.img
/usr/local/bin/mksquashfs.exe squashfs-root system.tmp -comp xz -Xbcj x86 -noappend -no-recovery -root-owned
cat system.tmp /usr/local/bin/sysdummy.bin > 02-system.tmp
/usr/local/bin/sfk.exe partcopy 02-system.tmp 0 6488064 2-system.img -yes -quiet
rm 02-system.tmp system.tmp
mv -f UNFEX/2-system.img UNFEX/2-system.bak
cp -f 2-system.img UNFEX/.
mv -f full_img.fex full_img.bak
cygstart ./refex.bat
exit
