Yeah I sent him a PM but no reply as yet.
Anyway I found the beta firmware after much trolling and can report it succesfully works with the cell link neo.
The viofo hardwire kit red and yellow wires are different to the cell link neo so you actually have to hook yellow to red and red to yellow instead of red to red and yellow to yellow. Once I did that it was all good. When you initially start the car the unit records in full 30fps, when switching off the ignition the unit will beep twice then instantly go into FPS mode which I had set as 5FPS. When starting the vehicle again the unit will beep another 2 times and return to full 30fps mode.
There is also a low bitrate mode but I am yet to test.
So far so good, I'll solder the wires together and make a more permanent install then give it a good test the next few days.
