alamsas
Hi guys, I have a '19 WRX and attached is my fusebox map under the driver's side.
I understand I need piggyback fuses and so I bought two.. but I realized I could plug the yellow (ACC) wire in one of the vacant slots. The red (Battery) wire however, needs to be actually piggybacked with another fuse that is permanently running (the ones that are always on are the ones with the green dots).
So I have 2 questions.. My piggyback fuse is rated for 15A fyi.
- Can I/Do I still need to use the piggyback fuse for the ACC wire if I'm going to use an open slot? If I do use it, do I just put in two 5A fuses in there? I would like to do a clean install so I don't mind doing that rather than wrapping the wire on a single 5A fuse and plug it in there.
- It seems like the door lock would be the least important fuse I could piggyback my Battery wire on. My understanding is that I'll use the same 15A fuse on my piggyback along with a 5A fuse correct? But if the piggyback fuse is only rated 15A, does that mean it won't work? Or is the 15A only for the 2nd fuse slot you use for the dash?
Thanks!
