Hardwiring Viofo A139 to 2015 BMW 4 Series Gran Coupe F36
Mtrev
Shropshire
A couple of weeks ago I hardwired the A139 into my BMW and thought I would just do a bit of a write up as it may help others with hardwiring their cameras especially given the issues that are sometimes encountered as a result of the battery management systems on modern vehicles.
For the hardwire I used Viofo's HK3-C hardwire kit.
For the fuse information I loosely followed the BMW instructions for their own dash cam product as this specifies a Permanent 12V (Terminal 30) ACC/ignition (Terminal 15) and an earth point (Terminal 31) A 2019 version of these is available here Advanced Car Eye PDF. My thinking for this is that it should then avoid issues from the power management.
BMW have played around a little with the terminal designations so now have Terminal 30, 30B and 30F as well as the usual 15.
Terminal 30B is what the lighter socket is connected to, this is powered for about 3 minutes after locking the vehicle then goes to sleep. If the car is woken this will then be activated again.
I decided to use a terminal 30B feed for the ACC instead of a terminal 15, this means that if someone was to wake up the vehicle such as triggering the alarm, the camera would be activated and power itself up. This means I can use a 1-2 hour parking mode or even turn the camera off when parked overnight but an intruder could potentially be captured by it.
For the power feeds the fuses advised are in the fuse box under the bonnet, this is less of a problem than it first appears as the fuse box seals to the bulk head so the hole to pass the loom through allows the wires to pass very easily rather than needing to squeeze them through any tight rubber grommets etc.
The fuse box on RHD cars is on the LH side at the very back of the engine bay, against the bulk head. Access is gained by removing a small cover held on by 3 90 degree twist 10mm heads. The fuse box is then underneath a small black lid which unclips. This is all opposite for LHD cars.
For the Permanent 12V I opted for Fuse 18 Shown at the top with the blue 15A fuse in, there was actually nothing connected to this fuse and this is the one advised in the instructions.
For the ACC wire, I used fuse 35 shown at the bottom which was empty. You could use fuse taps in these fuses to add the wires to them, because they were empty I crimped the terminals onto the wires as per the BMW instructions and inserted them in the plug connections on the rear. I then fitted a 5A fuse to each when I had finished wiring the kit in.
The correct terminals for this fuse box are BMW part number 6113 1378906
To route the kit I removed the passengers footwell under trim, the glovebox and lower A pillar trim. I removed the LH dash end panel that has the airbag switch in, if you disconnect the switch it will store an airbag DTC so leave it plugged in or disconnect the battery negative terminal unless you have something to clear DTC's with.
I also removed the upper A pillar trim, this unclips away slightly then pulls up to release its final clip.
To allow me to run the cable along the front of the headliner removed the LH sun visor and the LH mount of the RH sun visor, these are just held in by 1 TX 20 screw at each point so simple to remove. The front of the headlining is clipped to the roof above the interior light assembly but to make access easier I also lowered the light assembly as this is also quite simple as shown in the pics.
The black cover unclips to leave the assembly as seen in the first pic, there are then 2 metal clips (circled) and shown better in the second pic, this can be released with a small flat screwdriver allowing the assembly to be lowered.
This then left me in the position to start routing the wires. I started in the LHF footwell, with the carpet pulled back to give me access to an earth point and also some ducting to run the earth wire down as in the second picture.
I mounted the HK3-C box on the wiring harness underneath the glove box as shown and ran the red and yellow cables along the loom then through into the fuse box area, the pass through hole is shown in the second pic. Mounting the HK3-C box there means I only have to remove 2 10mm bolts to take the under panel off and I can access it easily if I need to.
I then crimped the connectors to the red and yellow wires and fitted them into the fuse box connections as shown earlier, fitted the fuses and did a test run of the camera to make sure it all powered as planned.
It is then just a case of tidily routing the USB-C cable to the A pillar, up the A-pillar and across the roof lining to the camera. I did this loosely then secured the cable starting at the camera so that any loose wiring ended up back near the wiring harness and HK3-C box as it is easier to secure it there than behind the headlining.
This has now been in place for over 2 weeks, used with a 1 hour parking mode, i usually drive 30-40 minutes each way to work plus a couple of local 2-3 mile journeys occasionally. Also today my wife took the car to work so I set the park mode to run for up to 12 hours to cover the whole 9 hours it was parked at her workplace. Looking at the SD card it appears it ran for 4 hours then I assume it hit the voltage cut off and powered down. The voltage cut off was set at 12.2V. The car has an AGM battery fitted but using diagnostics to read out the SOC this never exceeds around 70% State of charge due to the battery aging even after a full cycle on the trickle charger. No warnings triggered on the car for High rate of discharge or low battery warning when my wife returned to it so I am happy that all is working as it should be.
@bjornrepublic This was my hardwire post, your 440i will be quite similar but the link to the instructions is in the first post too.
So glad I used the search facility 🙂.... thx @Mtrev for taking the time to do a write up 😉. I'm currently doing research before I take the plunge and purchase 2 Viofo A229's - one for my wifes F21 and one for my F30. I suspect it would be the same as your instructions. Will keep you posted how it goes. 👍
Yes will be the same for the F30 and similar for the F21 although both are listed in the instructions I linked to. The only time the energy management has flagged an issue with the hardwire kit was when I decided to set an overnight park period, in that instance it had a dtc stored but nothing overly noticeable in the car.
Sorry to resurrect an old post but I am about to fit a VIOFO A229 dash cam to my F36 Gran Coupe so this is exactly what I need - it is a terrific write-up. As an Australian car mine is RHD so this is perfect.
One quick question, if you can recall. Once you have taken the lid off the fuse box, how do you then lift the fuses to get at the wiring? I suppose it is just a couple of clips, but if you can tell me, it will save me having to delve further.
Cheers and thanks.
Cheers and thanks.
I can’t fully recall but I think it was to release a tab down each of the gaps you can see in the picture taken from above, 2 either side and 1 each end. So try that first with a small pick or screw driver. If I get chance I will release mine and double check.
View attachment 56109 View attachment 56110
View attachment 56118View attachment 56119
Hi I would like some help, for the ACC you mentioned you used fuse 35, my f36 2017 fuse diagram shows 35 as engine size- would this 35 fuse not be suitable to use for me?
Have you checked if your car has a fuse in 35? Mine was empty
Hi,
I Just want to say thank you! Your instructions were exactly what I needed. I Had installed a BMW Car eye 3 on my f30. I used The factory instructions supplied by BMW. However The Cam was Not working right since IT did Not Go into parking Mode. After searching The net I ready that The BMW instructions are faulty. IT appears that they have switched The Red and yellow cable with each other. That means that although The camera does Turn on, IT does Not Work right. Your Pics and comments helped me fix that.
So again thank you very much.
Greetings from Germany
Hi,
Glad the post was of use to you. Was the error just in a newer version of the instructions then compared to the ones I linked?
