Mtz said:From the item description the dimensions are:
50 x 35 x 5 mm
Which value do you think created problems for you? Which value do you think can be bigger?
To be honest I'm not sure. I have a background in electronics and in reality the original battery in my opinion should be sufficient. With the charger plugged in the camera should really run off the power supplied from that, the battery simply used for backup after the charger is removed to power the cam during the file saving and shutdown period. The battery shouldn't drain at all with the charger plugged in (in fact it should charge up). It may simply be that the original battery was faulty/poor quality.
There is conflicting information about the capacity of the original battery and there is no info on the battery itself. The manual states the capacity is 800mAH but according to some Ebay sellers it is only 500mAH. Either way 500mAH in theory should do the job although the cam will only run for half the time without the charger than my new 1000mAH battery. I chose the larger capacity just to ensure it would fix the problem which it does seem to have done. It may be I could have gone with an 800mAH battery which would work equally well but without trying I wouldn't know. Hope this helps.
At least now I can run the camera for a longer period unplugged than I would have been able to do.
