- May 1, 2013
- Dublin
- Ireland
I think 27Fps comes from AVS Video editor each frame "jump" setting. Maybe it is not fully set to correct value. So if compare to 0803, Panorama and Mobius tests where I got same value, I can assume that AVS frame "jump" value is slightly incorrect. ( about 10% ). I will see if there any advanced settings in AVS to correct it. However regarding C3 it is strange having 15 double frames per sec. No other ideas than what @Isoprop proposed, or some firmware related thing ? ( not sure )27fps seems a bit of a weird number - I've just checked some footage I have here from the Mobius and I'm getting 30fps though (ie 30x the e key in VLC is a second or 30x the n key in RV) - is that where you're seeing 27fps?
I wonder if maybe the night footage is slowed down to keep the exposure longer for each frame and to make it slightly brighter?
