Hello,
I'm going to dive next month.
About 6/8 meters deep.
Now I see a lot of posts about a leaked case.
What is your diving experience with the Git2 case?
Should I go for the GoPro diving case?
If it is not used in wrong way or mistaken opened, our warranty will cover the the leaked issue and broken camera.
I bought the pro package from Banggood and have tested the diving case. I found vapor inside the case after submerging for about 10 minutes while pressing the buttons to select different modes and start/stop. I have raised it up before but no one seems to take any notice.
Okay that's promising. I will let you know how the diving went.
Where did the vapor come from? By pressing buttons? That's weird..
Indeed, silica gel bags are found on almost any new thing ranging from shoes and bags to high end electronics. These bags are also reusable, just use a dry heat source and it will drive the water out of them.those moisture balls (come in tiny packets)
That doesn't work very well, even sitting on a radiator in my house all day I don't get the last 40% out and it is that 40% which works best, the last 40% is very slow at adsorbing moisture, much better to stick them in your microwave oven for 10-20 minutes on simmer (very low), that will get them 100% dry.Indeed, silica gel bags are found on almost any new thing ranging from shoes and bags to high end electronics. These bags are also reusable, just use a dry heat source and it will drive the water out of them.
I think your kitchen needs a new more powerful microwave, since the old one still works it can go in the shed and be used for non-cooking activitiesI kind of have a restriction to use the kitchen tools and appliances with my hobbies, it all started with an old nVidia GTX card that needed a re-balling of the GPU and in lack of hot air or re-balling machine I used the gas oven. The next batch of cookies made in that oven were "extremely" flavored with hints of flux, burnt plastic and only god know what other goodies.![]()
