- May 14, 2013
- Oakland Park, Florida (USA)
- StreetGuardian.CAM Amazon.com
https://joovuu.com/community/index.php?thread/703-beta-firmware-25th-june/
Changelog:
How to upgrade your firmware (.bin) file:
ELF: mega.nz/#!TV1HmCaB!dv9y04H-UKC…MVpdbaLXgDl4nRUy01bc-ROAo
Changelog:
- Continuous recording file length problem - fixed
- Modified TXT command for white balance, image rotation, timed mode - fixed
- Changed the 'lock' file function
- Icons removed from HDMI out
- HDMI out causing the record to stop bug - fixed
- Shut down 10s delay added (app's to be updated)
- Random stop recording bug - solutions added - more testing needed.
- Download firmware from the below link
- Connect your JooVuu X or microSD card to the computer
- Place the firmware.bin file on the microSD card/JooVuu X. NOT in any folders.
- Insert the card back into the JooVuu X or simply disconnect the JooVuu X from the computer.
- Plug the JooVuu X into a wall charger USB plug or your car charger with the microSD card inserted.
- VOILA the JooVuu X will update. It takes between 1-2 minutes. Once updated it will switch off – THIS IS NORMAL. Please just press the reset button then the power button to turn it back on.
