rocknslope
With a brand new SG9665GC which came with a Kingston 32GB microSD card, I decided to use a 64GB microSD XC on the device that I had lying around.
Having tested the camera with the original Kingston microSD card to make sure everything works, I swapped it over with the Samsung microSD card. This is where the troubles started.
'Card full' and 'Card error' messages in blue pop up on start up. Going into menu and formatting the card, the device ends up freezing. I tried this several times with the same result.
Attempting to press out the card, it ended up stuck in the device. I eventually used tweezers to pull it out.
I put the original Kingston card in the device and it easily clicked in and out with no issue.
I tried putting in the Samsung card and it got stuck each time.
It's very difficult to tell, but I have a suspicion that the Samsung card is slightly thicker than it should be.
Also with the formatting issues, I would recommend avoiding Samsung EVO microSD cards.
