Mini 0803 coming
Does anyone know where I can buy some more adhesive pads for the mount, I have used both of mine already. Thanks
Here's a situation that is hard on most cameras I would presume.
YouTube compressed and custom over saturation (I'll add less next time), add to replace audio after YouTube made a fit about licensing.
Full version raw footage : http://eclx.net/autres/videos/20140615Pickup/AMBA0108.MOV (you may need to do a right click and save as)
WDR on, EV at 0, 1080p, super fine
Why do you all stay at EV +0 ?
I've already said that EV +1.0 is the best for 0803.
You cam points a bit to high as well, you can move it a click down to have better brightness.
Because I didn't got around to doing that at the time, I have set it up at EV +1.0 now. I'll give it a try to do a click down thanks!
My 0803 freaked out yesterday. It switched itself off whilst driving so I turned it back on and it started buzzing, making clicking sounds and the blue light was on solid. It wouldn't turn off so I removed it from the power supply and waited for the internal battery to run out. Refitted it in the car and now its working again.
I am wondering whether the internal battery is over charging as whenever I go any where it was always charging. Today it stopped charging for once and just the red light was on.
I have an issue with 0803 received today from Foxoffer.
I have ordered 2 GPS mounts, and both have same issue.
Look at the picture and video (red led is sometimes not lightning).
The 4 pins are not aligned, and disposed like Dalton brothers 😕
I suspect the left pin not to do a firm contact.
Received today 2pcs of 0801 mount to replace my defektive 0803 mounts.
Now, everything is OK, the 0803 stays firmy attached to the mount, no play between mount and cam.
Charging is also OK.
Thanks to Foxoffer support 🙂
It happened on me once a week. You can simply press and hold the power button until you hear no sound from the device.(about 10 seconds)
Can any one help this old man in distress, 🙁 it doesn't appear that when my 32 gb (Transcend) TF card is full it's not looping over it just stops recording.
Take out the card out and run on the 8gb internal drive and all appears to be okay.
Help please thanks
Did you go to setting -> Recycle-> Change it from OFF to 1/3/5mins?
I tried that. even held it for a couple of minutes and it still wouldn't stop. Had to leave the battery to die in the end.
Yes I made sure of that thanks.
It's happen a few times, it is set on 1 min at the moment, I have just reformatted the card again so I'll see what happens this time.
What else could it be?
Could it be that you have G-shock sensor settings enabled on the camera - so it's detecting a shock, thinking it's an accident, and then locking up all your files? I'm not an expert on this cam but some have G-shock + sensitivity settings. Personally, I have switched it off for my existing dash cam.
I've already made a LDWS test, posted in this thread
Hello. Tell please how to use LDWS? And firmware 0801 more nuanced than 0803. Will there be a new firmware with even greater settings and languages?
chris-s' post re. LDWS is here....
LDWS testing and GPS .srt from Registrator viewer testing 🙂
Calibration of LDWS is very simple.
The bottom line should be just up to the front of the hood.
The up line should be lower from horizon.
I've done manual calibration, it seems that there is an auto calibratoin but I didn't understand how it works.
It works fine as you can see but it is useless because the buzzer is just a whisper... I can't hear it on the highway, and too low to wake me up in the city...🙄
It also warns a bit too late, it waits that the line will be on the center of the hood...
Not sure about about the latest FW developments/languages. @Rayman.Chan - Any news about FW development for the Mini 0803, please?
Thank you guys. There are May's firmware on my 0803. If I turn on DVR with sound off in fact the sound is recorded. But if turn ON and OFF sound via Up botton, sound not recorded. In the the settings there is no click sound. In old DVR F500LHD you can choose how to enable sound.
That's because the sound off/on selection is the up arrow.
You are simply switching mute on again with the up arrow when the cam powers up
