Thanks a lot!You now can try to build your own modded firmwares: http://dashcamtalk.com/forum/threads/ambarella-a2-romkitchen.4092/
no startup and shutdown soundHi guys I see some custom firmwares here referring to "no sound". Is it referring to no sound when you press the keys or something else?
C:\Jado\Kitchen\firmware>cd romfs
C:\Jado\Kitchen\firmware\romfs>dir
Volume in drive C has no label.
Volume Serial Number is D204-54EF
Directory of C:\Jado\Kitchen\firmware\romfs
08.02.2014 14:28 <DIR> .
08.02.2014 14:28 <DIR> ..
08.02.2014 14:27 611.094 00___fonts.bin
08.02.2014 14:27 597.355 01___bitmaps.bin
08.02.2014 14:27 106.968 02___strings.bin
08.02.2014 14:27 28.260 04___no_thm.jpg
08.02.2014 14:27 14.281 05___invalid.jpg
08.02.2014 14:27 19.805 06___logo_off.jpg
08.02.2014 14:27 45.600 07___poweron_12k.pcm
08.02.2014 14:27 28.800 08___poweroff_12k.pcm
08.02.2014 14:27 6.176 09___shutter_12k.pcm
08.02.2014 14:27 1.086 10___short_shutter_12k.pcm
08.02.2014 14:27 9.300 11___optone_12k.pcm
08.02.2014 14:27 13.920 12___error_12k.pcm
08.02.2014 14:27 45.600 13___poweron_12k_low.pcm
08.02.2014 14:27 28.800 14___poweroff_12k_low.pcm
08.02.2014 14:27 6.176 15___shutter_12k_low.pcm
08.02.2014 14:27 1.086 16___short_shutter_12k_low.pcm
08.02.2014 14:27 9.300 17___optone_12k_low.pcm
08.02.2014 14:27 13.920 18___error_12k_low.pcm
08.02.2014 14:27 171 19___1_48k.aac
08.02.2014 14:27 185 20___1_44k.aac
08.02.2014 14:27 256 21___1_32k.aac
08.02.2014 14:27 342 22___2_48k.aac
08.02.2014 14:27 372 23___2_44k.aac
08.02.2014 14:27 512 24___2_32k.aac
08.02.2014 14:27 768 25___2_48k.ac3
08.02.2014 14:27 768 26___2_44k.ac3
08.02.2014 14:27 768 27___2_32k.ac3
08.02.2014 14:27 1.536 28___6_48k.ac3
08.02.2014 14:27 1.536 29___6_44k.ac3
08.02.2014 14:27 1.536 30___6_32k.ac3
08.02.2014 14:27 1.286.144 31___DVRPlayer.exe
31 File(s) 2.882.421 bytes
2 Dir(s) 10.333.851.648 bytes free
C:\Jado\Kitchen\firmware\romfs>del 07___poweron_12k.pcm
C:\Jado\Kitchen\firmware\romfs>fsutil file createnew 07___poweron12k.pcm 1000
File C:\Jado\Kitchen\firmware\romfs\07___poweron12k.pcm is created
C:\Jado\Kitchen\firmware\romfs>del 08___poweroff_12k.pcm
C:\Jado\Kitchen\firmware\romfs>fsutil file createnew 08___poweroff_12k.pcm
Usage : fsutil file createnew <filename> <length>
Eg : fsutil file createnew C:\testfile.txt 1000
C:\Jado\Kitchen\firmware\romfs>fsutil file createnew 08___poweroff_12k.pcm 1000
File C:\Jado\Kitchen\firmware\romfs\08___poweroff_12k.pcm is created
09.02.2014 20:51 <DIR> .
09.02.2014 20:51 <DIR> ..
09.02.2014 20:50 1.000 07___poweron12k.pcm
09.02.2014 20:51 1.000 08___poweroff_12k.pcm
31 File(s) 2.810.021 bytes
2 Dir(s) 10.333.339.648 bytes free
1. File -> Open
2. Export -> All
3. RomFS -> Export files
4. Modify files (wdir=[location where your fw binary is located]/rfs/)
Info: Keep the filename. Please don't rename the file. You'll get a semibricked device if you do.
Protip: Always save logos with Paint because it removes EXIF information.
5. RomFS -> Build RFS
6. RomFS -> Include in fwbuilder
7. Build -> A2 Firmware
09.02.2014 23:13 <DIR> .
09.02.2014 23:13 <DIR> ..
09.02.2014 23:13 611.094 00___fonts.bin
09.02.2014 23:13 597.355 01___bitmaps.bin
09.02.2014 23:13 106.968 02___strings.bin
09.02.2014 23:13 22.109 03___logo.jpg
09.02.2014 23:13 28.260 04___no_thm.jpg
09.02.2014 23:13 14.281 05___invalid.jpg
09.02.2014 23:13 19.805 06___logo_off.jpg
09.02.2014 23:13 45.600 07___poweron_12k.pcm
09.02.2014 23:13 28.800 08___poweroff_12k.pcm
09.02.2014 23:13 6.176 09___shutter_12k.pcm
09.02.2014 23:13 1.086 10___short_shutter_12k.pcm
09.02.2014 23:13 9.300 11___optone_12k.pcm
09.02.2014 23:13 13.920 12___error_12k.pcm
09.02.2014 23:13 45.600 13___poweron_12k_low.pcm
09.02.2014 23:13 28.800 14___poweroff_12k_low.pcm
09.02.2014 23:13 6.176 15___shutter_12k_low.pcm
09.02.2014 23:13 1.086 16___short_shutter_12k_low.pcm
09.02.2014 23:13 9.300 17___optone_12k_low.pcm
09.02.2014 23:13 13.920 18___error_12k_low.pcm
09.02.2014 23:13 171 19___1_48k.aac
09.02.2014 23:13 185 20___1_44k.aac
09.02.2014 23:13 256 21___1_32k.aac
09.02.2014 23:13 342 22___2_48k.aac
09.02.2014 23:13 372 23___2_44k.aac
09.02.2014 23:13 512 24___2_32k.aac
09.02.2014 23:13 768 25___2_48k.ac3
09.02.2014 23:13 768 26___2_44k.ac3
09.02.2014 23:13 768 27___2_32k.ac3
09.02.2014 23:13 1.536 28___6_48k.ac3
09.02.2014 23:13 1.536 29___6_44k.ac3
09.02.2014 23:13 1.536 30___6_32k.ac3
09.02.2014 23:13 1.286.144 31___DVRPlayer.exe
32 File(s) 2.904.530 bytes
2 Dir(s) 10.180.767.744 bytes free
C:\Jado\Kitchen\firmware\romfs>copy ..\HondaLogo2.jpg 03___logo.jpg
Overwrite 03___logo.jpg? (Yes/No/All): y
1 file(s) copied.
C:\Jado\Kitchen\firmware\romfs>copy ..\HondaLogo2.jpg 06___logo_off.jpg
Overwrite 06___logo_off.jpg? (Yes/No/All): y
1 file(s) copied.
C:\Jado\Kitchen\firmware\romfs>dir *power*
4 File(s) 148.800 bytes
0 Dir(s) 10.188.591.104 bytes free
C:\Jado\Kitchen\firmware\romfs>del *power*
File Not Found
C:\Jado\Kitchen\firmware\romfs>fsutil file createnew 07___poweron_12k.pcm 1000
File C:\Jado\Kitchen\firmware\romfs\07___poweron_12k.pcm is created
C:\Jado\Kitchen\firmware\romfs>fsutil file createnew 13___poweron_12k_low.pcm 1000
File C:\Jado\Kitchen\firmware\romfs\13___poweron_12k_low.pcm is created
C:\Jado\Kitchen\firmware\romfs>fsutil file createnew 14___poweroff_12k_low.pcm 1000
File C:\Jado\Kitchen\firmware\romfs\14___poweroff_12k_low.pcm is created
09.02.2014 23:17 1.000 07___poweron_12k.pcm
09.02.2014 23:17 1.000 08___poweroff_12k.pcm
09.02.2014 23:17 1.000 13___poweron_12k_low.pcm
09.02.2014 23:18 1.000 14___poweroff_12k_low.pcm
4 File(s) 4.000 bytes
0 Dir(s) 10.189.606.912 bytes free
Welcome to Amba A2 RomKitchen
C:\Jado\Kitchen\firmware\20140115-GPS-1CARD.bin
BST:
Start: 2048
End: 18097
CRC32: 0x77fb7962
Vers: 0.1
Build: 2014-1-15
Length: 15793
Entry: 0xc0100000
Flag: 0x0
Magic: 0xa324eb90
BLD:
Start: 18432
End: 144112
CRC32: 0xe8dddfdd
Vers: 1.3
Build: 2014-1-15
Length: 125424
Entry: 0xc0000000
Flag: 0x0
Magic: 0xa324eb90
PRI:
Start: 145408
End: 1828650
CRC32: 0x4209704a
Vers: 0.1
Build: 2014-1-15
Length: 1682986
Entry: 0xc0100000
Flag: 0x2
Magic: 0xa324eb90
RFS:
Start: 1828864
End: 4778240
CRC32: 0x180b8a60
Vers: 2.0
Build: 2014-1-15
Length: 2949120
Entry: 0x00000000
Flag: 0x1
Magic: 0xa324eb90
DSP:
Start: 4780032
End: 5183360
CRC32: 0x46731bb8
Vers: 1.0
Build: 2014-1-15
Length: 403072
Entry: 0xc34fffb0
Flag: 0x2
Magic: 0xa324eb90
C:\Jado\Kitchen\firmware\sections
Exporting...
Export finished!
RFS wdir created: C:\Jado\Kitchen\firmware\romfs
RFS to export: C:\Jado\Kitchen\firmware\sections\RFS_section.bin
Exporting...
Exporting to C:\Jado\Kitchen\firmware\romfs\00___fonts.bin
Exporting to C:\Jado\Kitchen\firmware\romfs\01___bitmaps.bin
Exporting to C:\Jado\Kitchen\firmware\romfs\02___strings.bin
Exporting to C:\Jado\Kitchen\firmware\romfs\03___logo.jpg
Exporting to C:\Jado\Kitchen\firmware\romfs\04___no_thm.jpg
Exporting to C:\Jado\Kitchen\firmware\romfs\05___invalid.jpg
Exporting to C:\Jado\Kitchen\firmware\romfs\06___logo_off.jpg
Exporting to C:\Jado\Kitchen\firmware\romfs\07___poweron_12k.pcm
Exporting to C:\Jado\Kitchen\firmware\romfs\08___poweroff_12k.pcm
Exporting to C:\Jado\Kitchen\firmware\romfs\09___shutter_12k.pcm
Exporting to C:\Jado\Kitchen\firmware\romfs\10___short_shutter_12k.pcm
Exporting to C:\Jado\Kitchen\firmware\romfs\11___optone_12k.pcm
Exporting to C:\Jado\Kitchen\firmware\romfs\12___error_12k.pcm
Exporting to C:\Jado\Kitchen\firmware\romfs\13___poweron_12k_low.pcm
Exporting to C:\Jado\Kitchen\firmware\romfs\14___poweroff_12k_low.pcm
Exporting to C:\Jado\Kitchen\firmware\romfs\15___shutter_12k_low.pcm
Exporting to C:\Jado\Kitchen\firmware\romfs\16___short_shutter_12k_low.pcm
Exporting to C:\Jado\Kitchen\firmware\romfs\17___optone_12k_low.pcm
Exporting to C:\Jado\Kitchen\firmware\romfs\18___error_12k_low.pcm
Exporting to C:\Jado\Kitchen\firmware\romfs\19___1_48k.aac
Exporting to C:\Jado\Kitchen\firmware\romfs\20___1_44k.aac
Exporting to C:\Jado\Kitchen\firmware\romfs\21___1_32k.aac
Exporting to C:\Jado\Kitchen\firmware\romfs\22___2_48k.aac
Exporting to C:\Jado\Kitchen\firmware\romfs\23___2_44k.aac
Exporting to C:\Jado\Kitchen\firmware\romfs\24___2_32k.aac
Exporting to C:\Jado\Kitchen\firmware\romfs\25___2_48k.ac3
Exporting to C:\Jado\Kitchen\firmware\romfs\26___2_44k.ac3
Exporting to C:\Jado\Kitchen\firmware\romfs\27___2_32k.ac3
Exporting to C:\Jado\Kitchen\firmware\romfs\28___6_48k.ac3
Exporting to C:\Jado\Kitchen\firmware\romfs\29___6_44k.ac3
Exporting to C:\Jado\Kitchen\firmware\romfs\30___6_32k.ac3
Exporting to C:\Jado\Kitchen\firmware\romfs\31___DVRPlayer.exe
Export finished!
Building...
Build finished!
Moved rfs.bin to C:\Jado\Kitchen\firmware\sections\RFS_section.bin
Compiling...
Loading header information from header.bin
Loading BST segments.
Loading BLD segments.
Loading PRI segments.
Loading RFS segments.
Loading DSP segments.
Reading section info from BST
Reading section info from BLD
Reading section info from PRI
Reading section info from RFS
Reading section info from DSP
Merging segments...
<BST> Patching security.. This will make any file valid!
<BST> Length patched!
<BST> CRC32 patched!
<BLD> Patching security.. This will make any file valid!
<BLD> Length patched!
<BLD> CRC32 patched!
<PRI> Patching security.. This will make any file valid!
<PRI> Length patched!
<PRI> CRC32 patched!
<RFS> Patching security.. This will make any file valid!
<RFS> Length patched!
<RFS> CRC32 patched!
<DSP> Patching security.. This will make any file valid!
<DSP> Length patched!
<DSP> CRC32 patched!
Patching header addresses...
Writing binary to disk. May take a while...
Build finished.
Please restart the appliction before using it again!
Hi Tobi@s,
Could you please prepare a custom with 20140115 firmware with this attached Scotland flag below, with sound, with GPS, no internal memory for me and others too use if they so wish ?
Gern geschehenSchönen Dank
Scott
Mini0801 Faulty LCD? | Mini 0801 | 0 | |
Fake Mini0801 internal views (red menus) | Mini 0801 | 39 | |
P | TS Version mini0801 Firmware Update from20130617 | Mini 0801 | 1 | |
Z | Mini0801 by Jado | Mini 0801 | 14 | |
Mini0801: First German reseller | Mini 0801 | 10 |
