TonyM
- Jul 30, 2013
- United Kingdom
- Mobius 1S Telephoto, A139, B1W
Was that in the middle of a clip or at the end?I saw something new yesterday on my drive home.
I've not heard of behaviour like that with the M2. In what way did it stop working? Was it not recording, or not turning on?
It seems to be an odd coincidence that the M1 is also becoming unreliable too. What problems are you having with it?
After a few weeks of testing I have come to my own conclusion that the M1 is currently a better all-round camera than the M2 for dashcam use. I know some other members already had that view a while ago. I suppose I 'wanted' the M2 to be better than it is and was prepared to give it a go despite the various warnings I read on these forums.
I have now relegated the M2 to the rear view window and reinstated the M1 up front, since I have more confidence in the M1 reliably recording the better footage of an incident.
After reviewing rear view videos from the M2 over the last few weeks, I've lost confidence that it can reliably record worthwhile footage in the event of an incident.The M2 performs rather well in very good light. WDR handles high contrast on bright sunny days. It's mostly when the light falls that it starts to struggle.
1080p60 tends towards over exposure, leading to washed out images, and also motion blur due to using a longer exposure time than necessary.
1080p30wdr blurs details when combining two frames to get the HDR effect.
I have had better results from the M2 at times, even at night, but the performance varies a lot. The M1 is capable of more consistent output at the moment. Exposure and colour balance are much better.
It's still early days for the M2. I bought it knowing that the firmware had a lot of development work ahead. The underlying hardware appears to have good potential. I am aware that the first public firmware update is coming soon, and I hope that it will deliver much improved results. Until then, I'm still using the M1 as my primary camera.
Did you use M1 for dashcam ?The M2 simply died. It switched itself off and stayed that way. The first time it happened, after a few attempts I managed to connect to it with mTools and a USB cable, and I was able to bring it back to life. But the second time it happened, I couldn't get it to do anything, and it wasn't recognised by USB. So I returned it to Amazon for a refund. A good reason to buy through Amazon!
The M1 started being unreliable a few months ago. It stated recording automatically, then the red light at the back stopped flashing and stayed on. It stayed on until I disconnected the battery or the battery ran flat. Restart it and it would work normally for a few minutes, then do it again. I reflashed the firmware (with the same version it had) and the problem seemed to go away, but it does happen after a while, just sometimes. Usually it works for many hours without a problem.
I think that it is overheating when it goes wrong, but I don't think the problem is being caused by overheating: seems more like the problem is causing the overheating: it doesn't make the heatsink triangles get more than warm before it goes wrong.
I wondered if the problem was in the power supply or the memory card, but swapping both seems to make no difference.
I've been using my M1 as a dashcam for 3 years, almost since it went on sale. Switched to capacitor about 2 years ago. I also have a capacitor in the M2.Did you use M1 for dashcam ?
then change battery by capacitor.
I found a similar blackout in my M2 recording this morning. Comparison with GC shows it's definitely a glitch with only the M2.I saw something new yesterday on my drive home.
