I'm quite aware that mSetup and firmware updates are not always linked. It was just a hunch - turned out to be correctmSetup is posted independently of the firmware and normally has nothing to do with when new firmware will be released.
But your hunch is right, the developer has given his OK to release the firmware. So, unless something unexpected turns up, it should be available any time now.
[EDIT]FW v2.02 is now available for (automatic) download[/EDIT]
More or less grainy than WDR on the previous firmware?Tested a little with latest official firmware.
and so far it seem WDR make footage grainy ( 1080/60 and /30 )
So many variables to play with
Hope I get a chance try the snow WB option soon - I'm switching to winter tyres again tomorrow.
I suppose the upper-weighted metering will be a bit like the low-cut option on the GC? And will we have to use lower-weighted if using the camera upside down?
Yeah, I had to chuckle a bit over the seemingly self evident choices of "Upper or Lower Weighted" for the M2 vs the SG9665GC designation of "Low Cut" (as in plunging neckline sweater.)
I'd like to think the developers thought of that, but it needs testing for suredoes the AE table also invert when the image is flipped?
OTG cable and Android app are a good way to make quick changes in configuration settings whilst in the car. Beats running inside to a computer every time you want to toggle WDR on/off or try a new metering option.Good question.
I am somewhat handicapped in testing with the mobius as i have no other means to connect with it other than my computer.
I could do it with the Asus tablet too i assume, but as i understand that demand a OTG cable, and i dont have one of those.
Besides the Asus tablet is also a pain to carry around, make me sort of wish my WP phone die soon, then again it have started to act normal again.
Fair point, however the advanced image settings (such as the metering options) are not mode dependent so need to be changed separately.I tend to choose two things I want to test at a time and set them up as mode 1 and mode 2 then give each a try
actually when I read that I thought perhaps you had suggested the naming convention, you're probably the only one I'm aware of that is more dashcam focused than everyone else that contributes feedback, the naming is not something I've worried too much about on ours right now as we still have work to do on the tables anyway, I'll sort that out once done
