I just bought 4 Mobius with B Lens from Banggood a couple of weeks ago to install as my first dash cams (front+rear) in 2 cars, and before I install them (and while waiting for the hardwire kits from Asia), I figured I would run some comparison tests between the firmwares. This is the closest I could mount them together, the videos are lower than where I will finally mount because I used 2 suction smartphone clips to hold the metal bar.
They are mounted with oldest firmware on top and newest on the bottom. This makes the newest on the left and oldest on the right when mounted in the car.
These are the relevant settings, all set the same
Mobius B Lens
60Hz Artificial Light
Wide Dynamic Range On
Video Data Rate High
Video Clip Length 3 minutes
Video Frame Rate 30fps
Video Resolution 1920x1080
Field of View Wide
Rotate Video 180 On
Both videos have the following layout:
0.59: upper left
1.13: upper right
1.17: lower left
1.20: lower right
Night comparison (be sure to change to 1080p)
The first few minutes of the video shows the advantage of 0.59, so I posted up the raw videos as well. If you want other segments of the video raw, just let me know and I can upload those too. Step 2 firmware cannot make out a lot of the peripheral trees, while Step 1 seems to show the trees quite well. 32 seconds in, you can see a lot of trees that are just empty darkness in Step 2 firmware. 1:40 - 1:45 also show the trees in Step 1. 3:25 shows the color shift to orange, so Step 2 seems to reproduce colors much better. This can also be seen in the Dusk comparison at 8:52 with all the yellow signs and yellow paint on the road.
Re-encoded at 8000kbps split screen video
0.59 raw
1.13 raw
1.17 raw
1.20 raw
Dusk comparison (be sure to change to 1080p)
It took me a week to find the time to figure out how to put the videos together into one video, but any subsequent tests should reach the internet much faster. I have currently reloaded the firmware to
0.59 -> 0.47
1.13 -> 0.53
1.17 -> 0.57
1.20 -> 0.59
and will perform another test soon. After that, my plan is to pick the best Step 1 among these 4, and compare it with 1.20 WDR On, 1.20 WDR Low Light, and 2.1X WDR Low Light.
I used AviSynth + avs2avi + x264vfw to put the 4 videos into 1 and ran 2 pass encoding at 8000kbit/s to make the file size reasonable to upload yet with good quality. My initial attempt using VSDC Video Editor resulted in ridiculous file sizes (16 min video, source 2.1GB each from RegistratorViewer with 1020ms overlap, ended with 8GB file even though the resolution stayed the same -- each source video shrunk to 1/4th original size -- plus the entire video only had 1 keyframe)
RegistratorViewer with 1020ms overlap to combine 3 min files into one file
Avidemux to trim the front and back of the video at keyframes
Script I used for AviSynth to shrink and align the videos to the same frame
h1=AviSource("night059.mov",audio=false,fourCC="X264").BilinearResize(960,540)
b1=BlankClip(clip=h1,length=3,color=$000000)
c1=UnalignedSplice(b1,h1)
h2=AviSource("night113.mov",audio=false,fourCC="X264").BilinearResize(960,540)
h3=AviSource("night117.mov",audio=false,fourCC="X264").BilinearResize(960,540)
b3=BlankClip(clip=h3,length=5,color=$000000)
c3=UnalignedSplice(b3,h3)
h4=AviSource("night120.mov",audio=false,fourCC="X264").BilinearResize(960,540)
b4=BlankClip(clip=h4,length=10,color=$000000)
c4=UnalignedSplice(b4,h4)
l1=StackHorizontal(c1,h2)
l2=StackHorizontal(c3,c4)
StackVertical(l1,l2)
Then I just ran avs2avi twice, once with Multipass 1st pass, and once with Multipass nth pass.
