OK. I feel stupid now.Set everything to default values and try it again and see how it looks
It looks better. A lot better at least inside the house (clip 2 place). Have to test it outside tomorrow.
Looks like changing FOV from narrow to wide was the trick. I didn't even remember I changed it.
Thank You!
well, thats the only thing i can do now, wait, but it will be hard to tell the difference until i get another one so i can compare side by side....My suggestion is to wait to get your camera and try it out. I just received my C lens and after a year with my A lens, I am impressed with the C. What a nice wide image with no flare and everything works fantastic.
can someone explain the sharpness, exposure and contrast settings in the "advanced imaged settings" tab?
Or is it only for still images?
Problem is my car is tinted very dark.
It's all about the light. My wife's Highlander doesn't get good footage as she has 40% tint on the windshield. My WRX had HID's with no tint and does much better for night recording. Is cutting a small section for the dashcam to see through a hole an option? Obviously you want to use a stainless steel blade like Olfa so you don't scratch the glass.
Wide, mounted next to my A Lens for a best of both setup.Are u using C in wide(original) mode or narrow?
As I said, I have the best of both, Wide and Narrow and not miss anything. The A set to record normal, while the C is set to Motion Detect. The amount of space they take is nothing and still quite discreet. If I chose only one, it would still be the A lensNight recordings must be very different then with the 2 lenses.
What's your reason for mounting them this way?
I'm thinking of just using the C on narrow mode setting.
