Mobius mounting solutions
Get the 3M Dual Lock Tape 😉
Dual Lock tape is a double sided tape product but it is NOT a hook & loop product. It has two sides with mushroom shaped polypropylene stalks that lock together very tightly and won't wiggle at all. Hook & loop type products will wiggle even if they are "industrial" strength.
For anyone in Australia looking for this the Scotch branded version is available in black at Officeworks
https://www.amazon.com/gp/B007OXK1AK***
US Amazon 3m Dual Lock Black 1 in x 10 feet.
Just a bit more then you may need but I use this stuff for everything that I use to use Velcro for.
BTW- Thank you for posting these mounts 🙂
***This one has a WHITE backing. Not good for stealthy setups.
I have Dual lock and it won't stick either.
The camera and the Braket have what seams to be a Silicon
coating on them preventing any thing I have to stick firmly.
Can I sand it off a bit or something?
Second one is maybe slightly more discreet but doesn't have much articulation or adjustment to it. Just tip up or down. The "ball" mechanism on the first one would give a better ability to adjust.
Looking at mounting options, I have got the suction mount coming with my Mobius but noticed the stick on mounts hang down less.
Am I right in saying these two mounts would work with the Mobius:
http://www.ebay.co.uk/itm/390690093199?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1558wt_978
http://www.ebay.co.uk/itm/390605658603?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_5650wt_978
If so, which is the more discreet? Is it the second link?
Does this mount with out the Velcro
Have a lower profile?
Any one have one? Didn't see the specs
Like the other ones.
You could use a short lens extension cable to give you the 90deg bit.
I'd be tempted to get the 8" lens extension cable so the mobius could, if needed, be put further out of the way.
I see from http://dashcamtalk.com/forum/threads/rearview-mirror-mount-for-g1w.4236/ that some G1W owners are attaching their dashcam to the rear view mirror stem /arm.
There is an equivalent mount available for the Mobius...
https://www.ebay.co.uk/itm/161054754291
I thought it may be of interest to some Mobius owners, who have a suitably-profiled rear view mirror stem /arm in their car. Apologies if this has been mentioned in any of the previous 247 posts in this thread.
I wouldn't get the angle for this on my mirror
Have my lens extension on order.
Making a custom casing for it so it will hide my camera. Will look just like some kind of rain sensor.
