This is my mounting for my VW Golf MK6. I bought a helmet mount and modified it. I replace the tightening handle by a nut and shortened the screw a little.
I also removed the 2 plastic pieces at the side (where you can put the strap through) and made the mounting plate a little smaller (it still holds very good to the windscreen).
The helmet mount has been glued to the mobius mounting base to save some space.
View attachment 12687 View attachment 12688 View attachment 12689 View attachment 12690 View attachment 12691
I like that ultra low profile mount.
If my VW would had rain sensor RV-mirror, I would build it Mobius remote lens into rain sensor. At one moment had crazy plans to swap whole windshield and buy RVmirror with rain sensor just because of that mobius remote lens DIY project, but now I am cooled down with that idea.
That was my first plan also, but there is no option to put the lens into the rain sensor. There is no room to put anything in it, so I had to go for plan B, but looks alright I guess.
This is how the inside looks like:
I guess if you could buy just the plastic housing without the mirror and add some small buttons at the bottom of the housing, then this is a great mounting solution.
The mirror makes it too expensive (for me). Just need to figure out how you could get access to the sd card and/or connector.
https://dashcamtalk.com/forum/threads/mobius-mounting-solutions.2654/page-21#post-94208Yeah, something like you did but to hide main unit not facing outside, but over top edge of RVmirror rain sensor cover on dotted area. I have seen someone "stole" ( telepathy ?) my idea and did it with Benz, but can not find it now.
http://www.mercedesclub.cz/user_images_category.php?id=486
I think I would have enough space in the upper part of the cover, but then it would be more difficult to take the camera out.
Update my mounting solution fell due to heat
Plastic glue turned to goo
Was this on your front windscreen I stuck mine on the black dots not had any trouble but I do place one of those sun shades on the screen when I am parked up which also helps protect the camera from the sun.
