Here are some interesting ideas I found online. I showed the web address then the supplied from google english translation.
Pictures are inside the links below.
http://www.revotech.cz/pouzdro-pro-kameru-mobius-actioncam/
(translated by google)
Today we'll look at how the big boxes from TIC-TAC vyrobyt waterproof case for camera MOBIUS ActionCam (Water resist Camera case). The housing is not waterproof diving (waterproof), but for recording in the rain, mud and dust well served. To produce the housing need 49 grams pack TIC-TAC at which the tip of the breaking knife carefully cut out the bottom. Despite bottom glue strip of translucent plastic or (1mm plexi from PhotoFrame IKEA). For gluing I used universal contact adhesive SOUDAL. The housing can be used for both versions of the Mobius camera lens Wide or Standard.
Pictures inside.
http://www.revotech.cz/krabicka-na-kameru-mobius/
As inspiration for owners of cameras MOBIUS ActionCam send pictures transport solutions in sturdy packaging. It's a box of servos Robbe 10g piece EPP and rubber strap 8 cm. Not only protects the lens, but the whole camera.
http://www.revotech.cz/mobius-ochrana-kamery-pred-vlhkem-a-vodou/
Mobius - Camera protection against moisture and water
When I bought Cameras MOBIUS ActionCam primarily for placement in the car, but also for shooting video on my models, I have not thought about its use even in an environment that would require additional protection against any weather. So I ponder how you do it gracefully and cheaply protection that would guarantee water resistance.
I know that for a lot of handymen, this is a primitive solution, but maybe someone just netrkne, so bring your solution.
Just one surgical gloves, or anywhere else sold soft rubber gloves Cut the fingers and the tip of the finger Cut a piece of rubber to produce a small hole with a diameter of 5 mm. Then utříhnutý finger String on a finger and roll it shape for a man familiar cap. Eventually it through the camera lens hole with the lid and rolled out throughout the body kamery.Tato primitive protection serves me quite a long time and one glove to give us any more "spare parts". The camera got wet when cycling and skiing and stayed in a blizzard.
http://www.pcpro.co.uk/realworld/385069/how-to-set-up-a-diy-dashcam
Eventually I fashioned a removable mount out of sugru, a putty similar to Play-Doh that sets as a strong, silicone rubber overnight.
It’s dead easy to make removable mounts for small gadgets using this magical material. First, cover the device – my Mobius camera, in this case – with a thin layer of cling film to prevent the sugru from sticking to it, making sure to leave a small gap between the device and the mount. Then, wrap sugru around the base of the device, overlapping the sides (but not the corners) so it’s held securely but can still be easily removed. Once the sugru has set, simply remove the camera and peel away the cling film.
I also performed this procedure around the stem that holds my car’s rearview mirror, so I now have an unobtrusive place to quickly and easily mount the Mobius.
