TonyM
- Jul 30, 2013
- United Kingdom
- Many dashcams over many years
I've been testing pre-release versions of the Mobius SLL1 (super low light) camera. Mobius don't make dashcams per se, but their products are sometimes appealing to dashcam users, if you don't mind being creative and making your own screen mount etc...
https://mobiusactioncam.com/mobius-sll1-camera
So why would you consider using this as a dashcam. In short, it captures more light than any other small camera I've used. I even used it to record 'real-time' video of the aurora last year.
It has a high-sensitivity 2MP sensor
It has a fast F1.0 M16 lens
It has a Low Frame Rate (LFR) option which works a bit like Viofo's SNV parking mode, except it records audio and the frame rate remains constant at 30fps. It adjusts the exposure time from 1/30s to as slow as 1.0s, and duplicates as many frames as needed to keep the 30fps output going.
At dusk in low light where HDR is not yet effective, it uses a shorter exposure than any camera I've seen, meaning less motion blur and better number plate capture.
Low Frame Rate Example
Here's an example I shot this week, parked in a virtually unlit church car park.
First up, the Vantrue E1 Pro with its IMX678 STARVIS 2 sensor, HDR enabled, PlatePix disabled. Almost complete darkness.
Next, the SLL1 with LFR turned off, so full 30fps. We can see the tree outline against the sky, but not much more. However this is slightly brighter than I could see by eye.
And last, here's the SLL1 with LFR enabled, running at it's lowest effective frame rate of 1fps (30 duplicate frames per second).
Yes, I did stand still for more than a second. At normal walking pace I was just a blur.
