This is mainly bug fixes to all the things that appeared in the v2.10 compiled with new developer's code libraries, as well as a number of nagging things the user base has found and lived with for a while. Here's the list of the changes:
NOTE: You must download v3.0.3.0 of the mSetup.exe GUI program to configure the Mobius with a Windows PC running this firmware.
BUG FIXES:
1. Fixed unexpected recording termination in Time Lapse Photo mode and with certain video clip lengths
2. Fixed non-functional Contrast control function when Vivid Color Option is ON
3. Fixed non-functional Mono Color Effect setting.
4. Tweaked the WDR settings a bit.
5. Fixed inoperative "Power Off with external power disconnect" function in Time Lapse Photo Mode when "Auto Record withexternal power connection" function is set.
6. Fixed PAL (25 and 50fps) recording to record unique frames, but there is still an obscure problem during playback that causes the video to notplay back smoothly. Some players (e.g. VLC) show jerky motion whereas WMP is much better, though still noticeable.
7. Fixed off-center 1080p Narrow video frame.
8. Fixed large jump in first Exposure Function increase increment above mid point
9. Fixed File protection bug that only protected the last file in a continuous sequence. Now uses this logic:
a. If the current running file is less than 1 minute, it should lock previous file and the current file.
b. If the current running file will be closed less than 1 minute, it should lock the current file and the next file.
c. If the current running file has recorded over 1 minute and will be closed after 1 minute, only the current file is locked.
NOTE: You must turn on your folder options to show the "Detail" file view with the file "Attributes" tag toggled on in the folder header. You can toggle those by right clicking in the folder display area first to turn on the "Details" view, then right clicking in the folder header to access the "Attributes" tag check box in the "more" link. Protected files will show an "R" flag to indicated the file is "read only".
10. Fixed inconsistent timing when when Time Lapse Photo delay was set greater than 1 day.
11. Added a Card Format option to select FAT32 or exFAT for cards greater than 32 GB capacity. Currently formatting 128GB cards with FAT32 does not work in the Mobius does not work.
12. Eliminated the "weak" intermittent and moving scan line near the top of video frames in the Narrow mode.
13. Fixed failure of a new clip to be started at the 4GB file size limit if the camera was powered by a standard 4 wire USB data cable plugged in a computer USB port.
KNOWN ISSUES REMAINING:
1. Jerky play back in PAL video modes (25 and 50 fps). It varies with the video player (VLC is much worse than WMP). There are no dropped or missing frames... just a playback issue, maybe codec related?
2. No way to tell the camera is in "sleep" mode between frame captures with very long time lapse photo modes. Maybe an LED blink every 10 sec. or so would help?
3. Time lapse Photo Mode delay must be set to 2 sec. or greater when Video out is turned on (a hardware limitation). Plugging in the Mobius video out cable with it's pin 4 grounded to pin 5 turns on video out starting with V2 cameras. Any lower setting will be changed to 2 sec. by the FW, and will not be reset when video out is turned off! If video out is not needed, do not use the stock video out cable to provide external power to the camera if you want a delay setting less than 2 sec. Use any generic USB 2-wire power source.
4. In-camera formatting of 128GB cards with FAT32 does not work at this point, but can be done with some external formatting programs.
The FW is getting very complicated and nearing the mature point where further enhancement becomes less practical, I think.
