Dashmellow
- Sep 22, 2013
- Uncanny Valley (●_●)
- United States
- Umpteen
wonder if a super capacitor is better in a dash cam?
Yes!
there are so many. Recommendations?
Yup, that is how I have it setup already.BTW, if you install a super-cap in a Mobius be sure to set "Power-OFF Disconnect" to "Immediate" in mSetup.
Good to know. Thank you! My goal is to have the file written to SD when power is cut.In your location either will do fine. Supercaps are more tolerant of temp extremes and last longer but they also must stop the recording the instant that power is cut, whereas a battery can keep going awhile. In a crash it's at least somewhat likely that power could be cut- by then any dashcam has captured the cause and the crash, but not any aftermath which a battery powered cam will get while a cap powered cam won't.
So IMHO the battery is better if it's a viable choice
Sadly no, but I just changed the lens itself, not the CMOD casing or anythingDid you try it before changing the lens?
Yah, didn't think this was going to happen...that's a shame, would have been better to find out this was an issue before breaking the warranty seal, going to have to wait on the seller to respond I guess
Okay so I just got my brand new mobius 1 and it is not working. Here is everything I know so far:
Any ideas?
- I changed the lense
- When I try to turn the mobius on the blue light comes on for a second and then the red light at the back blinks 3 times.
- When I plug in the camera it is not recognized by any of my computers, and no lights come on. If I try to turn it on, the green light stays on but still nothing happens. I have left it charging for 3 hours in case that was the issue, it was not.
- The CMOS connecting strip is perfectly aligned and in tact on both sides
- I reformatted my SD cards and tried multiple SD cards
- I tried all different types of firmware, and when I try to manually load the firmware the blue light blinks as it should, and once it is done, the red light blinks 3 times (no yellow light) and then the camera goes dorment again.
- I bought it from this website: https://www.mobius-actioncam.com/category/video-share-blog/ and their customer support sucks ass and has not responded after days.
Remove the lens again and reinstall it. Make sure that the ribbon cable is fully inserted into the socket and seated properly after you plug it in. Make sure you lock the ribbon clamp.
As for not being recognized by your computer make sure you are using a USB cable that has a DATA connection. Some cables only have wiring for power, so it they charge the camera ONLY when plugged into a USB port. i.e. make the green LED light up). The short cable that came with your camera should have the DATA connection. It is also possible that you have a bad cable.
Try a different memory card.
The BLUE light on start-up is normal. The three RED flashes are also normal. (three red flashes indicates a full battery - two flashes less charged and so forth)
If nothing happens after the above sequence try pressing the reset button or remove the battery for 30-60 seconds and plug it back in.
Good luck!
So I put back the regular lens (like that would change much), re-seated it -- this is the only area where I think I could be going wrong, it is fitting quite snug but maybe I am not doing it right?? I put the memory card in, pressed the reset button and did all of this multiple times... Still nothing.
Also, the USB cable does do data transfer as I just tested it with a go pro and it worked.
It's not to be found anywhere on the PC. I formatted the cards using SDformatter.exe to FAT32. If I put the firmware on the SD card it loads the firmware with the blue sequence, but the yellow light never shines. If I turn it on and off again, it goes through the whole sequence again. The firmware never gets deleted off the SD. Yes it was in the camera and I have tried multiple.If you're using PC, Try opening device manually. Also how did you format your SD card? Is it in camera?
Current Mobius 1 sell with A2, C2 or D lenses. Previous lenses are A, B and C1.What is the latest lens for mobius 1? Which one is best for dash cams? I can't figure out the lens in the mobius that I have, it says "Mobius_SE_V0.1". Any ideas?
E | Looking for original Mobius1 | Mobius | 3 | |
V | Mobius 1 vs maxi 4k ...FOV | Mobius | 0 | |
T | Mobius suddenly acting screwy - solid blue light on startup | Mobius | 9 | |
J | Mobius dash cam problem | Mobius | 55 | |
Mobius software | Mobius | 2 |
