Nigel, yeah that is a concern of mine to, that they have not started developing anti vibration mounts of mounting, to eliminate
shaking in the video etc. It has a huge impact on quality of video, even at high speed. Same thing for people using FPV radio
controlled aircraft that get jello in the video etc. It is horrible, sure, image stabilization helps but it can only do so much.
One of the clips from the 0903 I downloaded from mega (someone posted) had a good enough bit rate, about 23Mbps
for 1080p 30fps and that is enough for good video, and occasional blocky video, but for the most part should be
fine. The image quality was great and you could read license plates easy.
But I think, if the people at the "mini" camp could come up with a nice smart anti vibration mounting for the camera
that would help a lot with the quality of the picture. The problem is that when you are filming thing far away, little
shaking has a lot of impact on the image compared to when things are close up to the camera. It would need some sort
of semi-suspending of the camera in the air, attached to the windscreen. Do not ask me how, but if you look at how many
of these mounts are made, you could probably create something that would work great.
The sound is real good, great microphone, although I would prefer the option to use AAC audio instead of PCM
but that is something they can add in firmware anyway, no big deal. I know it takes time to work out bugs, add
new options etc. As long as the hardware is good
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
