- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
seems like it has 24awg power wires and 28awg data wires, odd combo but would probably do the job
I don't think that will work as ultimately it's still 28awg but with added gold connector and ferrite core.
Sent from my SM-N950U using Tapatalk
Mini b5, was the one I have currently that doesn't work. The one you linked stays mini b4, will this work on the A119s? Some fo the reviewers were mentioning it.I don't think that will work as ultimately it's still 28awg but with added gold connector and ferrite core.
The power wires are 24 gauge and I believe that is likely where your problem lies. Standard 28 gauge USB data cables are rated for 15 feet but 28 AWG for current at 15 feet may not cut it for this camera.
Ok,.cheers ordered it.@Limeybastard, I got to thinking that the 15 foot Monoprice cable I use for my rear Mobius is actually a 5pin so I had another look over at Monoprice and sure enough they sell the same cable in a 4 pin and a 5 pin version.
Sorry I missed that!
So, get this one!
https://www.monoprice.com/product?p_id=5450
Thanks. If not then I'll have to just order the slightly shorter genuine Viofo USB cable.I've never had Monoprice not ship me the correct item I ordered. In any case, so far it sounds like an improvement. Hope your problem is finally resolved.
Where can I purchase a genuine Viofo USB power cable?
Thanks.Where can I purchase a genuine Viofo USB power cable?
either @CaptureYourAction or @OCD Tronic should be able to help you out if you want to get the OEM cable
The cam didn't fully power on today. Red light was on but wasn't recording until I unplugged the power and rebooted it. Otherwise , it was working ok with the monoprice cable. Bearing in mind the screen does flicker a little on initial bootup.
With the previous cable it would flicker bad with horizontal lines and give mem error.
It does make sense to me. With the previous monoprice cable the screen would have horizontal lines and flicker immediately on power up. Then throw a mem error.
With this current monoprice cable , the camera slightly flickers on power up but generally works 9 times of 10.
Just ordered a genuine USB power cable from capture your action.It's not the power supply. It does the same when I use the source that my existing stable A119 uses. I've already covered all of that in my previous posts.
