Harsh
I've messaged the seller asking the MP count and whether an IR filter can be installed at their end, let's see.
Seller got back, it's 1MP and the filter can be added.
Back on sale, but I'm sure the price has gone upI think its sold out.
Yes price seem steep, but its a lens jungle out there, and i figured if peau was selling it then it cant be all bad.
https://www.peauproductions.com/col...s/products/12-00mm-f-2-0-30d-hfov-3mp-gp12020
Oh, you stated where doe's it end?, When you go out to work and see that you need a new truck mount for the cameras you are driving !
Just search for, "M12 lens lock rings". (Jam Nut) They are available and not too hard to find.
@dirkzelf
The Mobius looks like a sci-fi laser weapon sitting there Good job on the mounts- simple and effective
I encountered a few teething problems in my aim to run a 4mm F1.2 and 6mm F1.2 side-by-side in my 2No Mobius 1 cameras. I started out with an original A-lens camera with the early production case (with a round LED), and a much newer lens D camera. I successfully modified the lens hole on the original case to accept the 6mm lens barrel. Managed to get it focused easily and locked off with the set screw. So far so good. First test run tomorrow
Then I tried to swap the D lens for the 4mm F1.2. It was then I found that the D lens was glued in to the lens holder, and there is no set screw on this new Mobius 1 It's also a plastic lens body rather than glass, so I had to be extra careful cutting away the glue without stripping the lens thread. I did get the glue off, and managed to remove the lens. Then I noticed that the D lens holder has a much shallower threaded depth than the A lens, approx 6mm vs 12mm. Unfortunately that was not enough to hold the lens thread secure once it was in focus - it almost fell out just by tapping the camera. So that lens holder is only good for lenses with a short back focal length
Thankfully I have another A2 lens Mobius on order, which looks like it has a good length lens holder so I can swap out the A2 for the 4mm F1.2.
Thanks. I have a spare C2 lens module & lens that I salvaged from a damaged mobius. I can try removing its lens holder to see if that works.You can buy a deeper aftermarket M12 threaded lens holder and simply swap it for the shallower original.
Here's an example of one that is 16.5mm tall with 18mm screw hole spacing.
http://www.m12lenses.com/Plastic-M12-Lens-Holder-p/pt-lh007p.htm
This business of Mobius doing away with the adjustable focus lenses is a huge step backwards!
E | Looking for original Mobius1 | Mobius | 3 | |
V | Mobius 1 vs maxi 4k ...FOV | Mobius | 0 | |
T | Mobius suddenly acting screwy - solid blue light on startup | Mobius | 9 | |
C | How do I change back from dash cam mode to the original settings. I want to put mobius on my drone. | Mobius | 6 | |
Original Mobius?? Cheapy?!? | Mobius | 6 |
