So you cannot see the big exclamation mark on the A129 screen, and the remote car screen is only active when you reverse?When I press the button I don't hear that the recording is being saved.
Since audio out via the cable is already enabled, perhaps you can connect a basic speaker hidden somewhere around our behind the dashboard?
@viofo
I'm currently on software 1.5. I found an error.
When I disconnect the power and connect it again, the video from two cameras is displayed.
The camera does not remember that it was set to display the video only from the rear camera.
Is that specifically the AV-out which reverts to PIP on restart? The A129's own display maintains the same setting from when it was last used.it's not an error, it will revert to PIP mode whenever it restarts
We plan to solve this, but have been told by engineer this is to avoid rear camera handshake issue.if they're not doing it on the display then it may be that they're only doing that to the AV out, if you don't have PIP at reboot it affects the rear channel handshake, we don't have AV out on ours so we do that on the display output
Hi, Viofo, thanks for new FW version !Updated V1.5 firmware for public testing.
This is kind of the point to the Bluetooth button. It locks the current file, just like pressing the ! button, but conveniently placed for easy reach.Hi, Viofo, thanks for new FW version !
we do not want to lock large video file at all (and spoil free SD space).
Why do you want auto reboot?I want timelapse mode to switch to regular recording when gsensor activates (like blackvue). As I understand it, if youre hit, it still stays in timelapse
Additionally, an option to enable daily auto-reboot at a specified time.
Also, enabling an option to enable WDR ONLY in parking mode would be great (blackvue has this). WDR while driving where you have headlights really degrades the quality, however WDR while parked is a great thing to have.
Also I was asking that some time ago. For example the reboot time to be at... 4:44AM.Just in case something isn't working well and you might not know it's not working. Rebooting would likely solve that
3-wire hardwire kit
Time-lapse 5fps
21:33:22 - Car turned off
21:33:28 - Parking Mode (5fps time-lapse) begins, 6 seconds gap
21:45:27 - New Time-lapse file starts, 4 seconds gap
21:46:29 - Car turned on
21:46:53 - Normal recording resumes, 24 seconds gap
@viofo Why is it taking 24 seconds to switch back to normal recording? With the 2-wire kit it takes 7 seconds. Seriously hope it's a bug.
I did recheck in my car, found it only take 3 seconds to switch between the normal recording and parking mode time lapse recording.3-wire hardwire kit
Time-lapse 5fps
