Parking mode
golgeoyunu
Turkey
Auto parking mode wifi off firmware has time issue,the camera have to connect the device to sync the correct time, that is still continue? or it is fixed?
estore009
Retailer
Shenzhen
China
B1W/Mini0906
The capacitor cannot keep time after a long time parking and suggest that you sync time every Monday after weekend parking.
Leonauto
Smolensk
Russian Federation
StreetStorm A7810-G_Pro, Ausdom A261, B1W, Viofo A119 PRO
Not quite clear what needs to be fixed.
With the external power off, the dash saves time for up to 20 days, or did you mean something else?
golgeoyunu
Turkey
Im using my car everyday
Wow the dash saves time period is really enough. I think it saves time 1-2 days.
egalitarian
Bulgaria
The only thing that probably needs fixing is the power usage in park mode being the same as when the camera is running. My guess is that this is done for the camera to be ready and start recording immediately when g-sensor event occurs or maybe it's a bug. But we really should have a choice if we get the more parking mode time or less time between event and starting to record.
Spawner
Hi! just registered. for the hardwire for auto parking mode default wifi off does it have to be hard wire to continuous power? or can i hard wire to ignition on only? i have the b1w hard wire kite. i only connected my red cable (did not connect the yellow cable) to ignition.
@estore009 can i get the auto parking default wifi off pretty please?
thank you all.
estore009
Retailer
Shenzhen
China
B1W/Mini0906
Hi, estore009! Sed me, please auto-parking firmware. Thank you!
PM you already, please check your inbox message!
Yes, red wire to an always-on socket, and Black wire to GND, Yellow wire unconnected! And PM your firmware already, please check!
rajoar
Spain
B1W
Hi, estore009! Sed me too, please auto-parking firmware. Thank you!
RegB
South Africa
@estore009
Just received my dashcam and would like like the latest firmware fir the parking mode please
estore009
Retailer
Shenzhen
China
B1W/Mini0906
BobsleiiG
France
Just a passing idea that would be well worth adding on the "double click" firmware.
It would avoid choosing between having unwanted detections or missing shock detections.
It could be an option in the settings to allow the sensitivity to switch between the mode "recording" (recording mode) and "in stand-by" (parking mode).
For example :
- recording = medium
- parking mode = hight
Juste une idée en passant qui serait bien utile à ajouter sur le firmware « double clic ».
Elle permettrait d'éviter de choisir entre avoir des détections intempestives ou rater des détections de chocs.
Il s'agirait d'avoir une option dans les réglages pour pouvoir basculer lors du double clic entre les différents modes (« en enregistrement » (recording mode) et « en attente » (mode parking)) la sensibilité de détection.
Par exemple :
– enregisrement = moyenne
– mode parking = élevée
Rippernz
New Zealand
Hi, may I also get the link to the auto parking mode firmware also please.
Sent from my Pixel 3 XL using Tapatalk
BobsleiiG
France
For example :
Par exemple :
Do you think that is possible?
nsns
Serbia
Hi @estore009 . Can you send me firmware with Wi Fi off double tap to enable parking mode and firmware wi Fi off AUTO parking mode?
Thank you.
Sent from my LG-H990 using Tapatalk
estore009
Retailer
Shenzhen
China
B1W/Mini0906
PM you already, please check!
Similar threads
