Parking mode
Hi there @estore009
Could you please PM me the auto parking mode firmware (both wifi on and off)
Thanks in advance!
Hello @estore009
Can you please PM me a link to the parking mode firmware with wifi off? Does this firmware also include the double tap to enable parking mode?
Thanks!
PM you already! Please check your inbox message!
Hi @estore009,
Could I please have the ‘double-press’ button to turn parking mode on and off firmware please, both versions for wifi on and off.
I think I’d prefer to do this manually.
Hi @estore009,
PM you already, please check!
Здравствуйте! И я хочу иметь прошивку в которой режим парковки включается двойным нажатием кнопки. При включении вай -фай выключен. Спасибо!)
Hi, @estore009 !
Could you please PM me the Auto parking mode firmware?
Thanks in advance!
Hi @estore009,
Many thanks @estore009 for your very prompt reply, as always great service...
... I’ve been testing this double-tap to turn ‘parking mode’ on/off firmware today and it works really well.
The reason I wanted this is that I had issues with the ‘auto-parking mode’ firmware I’ve been trying - 20180614S wifi off...
... when left on a table that certainly doe not move I still get a lot of 3 minute recordings.
For example, when left in ‘parking mode’ for 7.5 hours it still recorded around 2.5 hours of recordings. I tested it several times and the LED seemed to indicate that while it stopped flashing for a while, without any movement it started to flash again. It always seemed to record for half of the time or more.
Has this been noticed by others and a bug that will be fixed?
PM you this double-click firmware already!
Yes, PM you already, please check your inbox message!
Hi @estore009
Could you please PM me the auto parking mode firmware (both wifi on and off) as well as the double-click firmware (both wifi on and off)? I will report my experience testing them back here!
Thank you very much!
Hi @estore009
PMed you already!
Can I get the auto-parking mode firmware, please?
so with the parking mode firmware, I will need to double press on the buttont to activate and deactivate it? What if I forgot to activate it and got out of the car? Recording will continue like normal until battery power cutoff?
Yes, this is the standard operation with the firmware 20180528s
Yes, it is!
And you can load the 20180614s firmware
If you have big car like van or you parking on windy place (close or between buildings too) it can be reason. How is your G-sensor configured? medium or low?
