- Nov 25, 2013
- Shenzhen
- China
- B1W/B2W/B2K/B4K/DV688/DV988/B1M/B2M
PM YOUIs there a auto mode Wi-Fi off?
What happened to the low FPS parking mode firmware? Is it still available?
Some tester feedback me it is not stable, so...
I was one of the 1fps beta FW testers. Myself and other testers including @Nigel had similar results to each other, including some very short 1-2 second clips, through to some long-duration files that would not playback at all. I think the problems arose when trying to switch between modes automatically.Hi. Are you then giving up on this incredibly desirable feature? Additionally, can we have access to the flawed beta at our own risk? Maybe the instability doesn't exist in all cameras, or some work around solution can be discovered if more testing and experimentation reveals the exact issue(s). Surely a camera that can handle 30x the workload can handle 1/30th. Let's not give up on this. It would be an amazing feature that would set this cam even further apart from the rest. Let's definitely not give up on this.
Great suggestion, also it can record the sound when someone hits your vehicle while low framerate does not.From my experience testing the A129 I would recommend a continuous low-bitrate parking mode rather than a low fps parking mode. In my opinion, 1fps misses too much action if there's something important to record. 30fps at 4Mbps doesn't take up much space at all.
Few people would realise that a low bitrate parking mode is worth having, until someone like Tony recommends it. After all, everyone knows that low bitrate = poor quality! Reality is a bit different. Sometimes, if you want these things you have to ask, which is how it comes to be available in the A129.Something along those lines does sound like a fantastic alternative, but I guess I assumed that an option seemingly easy like that to implement would already exist in the b1w and many other seemingly possible cams, unless it was not viable for some reason. Hopefully a very incorrect assumption.
PM you already, please check!
OkCan I have the firmware with WiFi always OFF?
I think you need to ask for auto parking mode firmware. Sounds like you constant recording firmware, which is what I have.Update on my parking mode test.
I have set to medium g-sensor and recording 5 minutes. Left the car in blinking red (recording with WiFi off). After 10 minutes, the light is still blinking red. Why is it not going to parking mode?
Update 2:
Been checking on the recording the whole night. It just never go into parking mode. Just constant recording with blinking red.
@estore009, am i in the correct version? why did it happen? it never go into parking modeHey, I'm using the auto parking mode version with wifi-off and it looks like the camera never gets into parking mode, I can see that it recording all night long.
I was still testing the auto parking mode so it was left on a dining room table overnight with no movement or air movement. I did this for a couple of days but it always records for around half the time it’s left on. The G-sensor is set to the recommended medium setting.
M | Parking mode issue | B1W | 4 | |
T | B1W: Parking mode wiring help needed please | B1W | 1 | |
J | Looking for a firmware with the iOS fix and parking mode | B1W | 2 | |
S | Parking mode? | B1W | 2 | |
C | Parking mode and battery pack | B1W | 5 |
