Jacko956
- Jan 26, 2018
- Manchester
- United Kingdom
- Nextbase 512gw, 512 rear
There's a firmware update 22.5
Does anybody know what is actually upgraded in 22.5 ?Been running fw22.5 since yesterday. It has not solved my blurry, out of focus image quality from the front camera. I'm not sure exactly what has changed in the firmware but the file size of the front and rear camera is exactly the same as before hand.
Its ok if I unplug the rear camera
that screen shot above is out of focus, if you're not checking it at the same time with/without the rear connected then I would suggest that you do, if the focus is drifting that's still a warranty issue, hottest part of the day is when you're going to see issues, particularly if you had been parked in full sun
Good point, the car had been parked in full sun and this was taken 10 minutes after setting off. Looking at the footage it was still blurry when I set off this morning and the car had been garaged overnight
I'm getting 404 errors.
Could be because they are http and browsers now use https ?
K | Front & Rear Hardwire, rear cam intermittent problems | 512GW | 2 | |
R | Front and rear hardwired, never has any battery. | 512GW | 5 | |
L | Nextbase 512GW front and rear cam fitted | 512GW | 3 | |
Does this level of picture quality seem right? (front + rear cam) | 512GW | 16 | ||
Y | New System (Front and Rear), where to start? | 512GW | 9 |
