Installing 2 single cameras are nothing new, what we addicts did before multi channel systems became possible, some also still do it for redundancy reasons, the only downside is you have to go to 2 cameras to get footage.
What i did as i found out the hard way that powering a camera from the front with a 16 feet long USB cable was no good, i then tapped into a 30 A fuse in my car and put one of those 3 way 12 V socket adapters under my rear seat ( drawing the GND from one of the bolts that hold the rear seat in place )
In 2 channel systems the rear camera are powered with the one wire from the front camera that also send footage to the memory card in the front camera, so nothing else is needed here.
Using 2 dual systems to get a 4 way system using the smaller rear cameras for side cameras are nothing new, this is quite doable, only you need to extend 12 V to the rear camera as extending the 5 V USB wire are not a good idea.
If you hardwire, you can graft into the same 2 fuse taps you would need if it is a 3 wire hardwire kit, and do that with both systems so you will not need to tap into 4 fuses ( 2 for each system )
I have run up to 8 cameras on such a setup with just a 5 A fuse for the fuse tap side of things. ( tapped into 10 A fuses )
As i change often i have the 2 fuse taps and the GND come to a wire screw terminal so i can easy remove or add more cameras without having to go to the hard to reach fuse box in my car.
While hard wire kits do come with a not too small 12 V wires, it would probably be too short to reach out back even of a almost micro car like mine, but the 12 V wires you can extend as much as you like.
So in my case, kneel at driver side door, reach in, grab screw terminals, remove or add additional wires, and BAM in less than 5 minutes i am ready to go at least in that aspect of the matter.
As i recall
@Vortex Radar have been running systems like that.
Me personally i rean a regular front / rear system and then a dual remote system for side cameras, which was nice CUZ the K2S system had extremely small camera units, like half the size of most rear cameras.
And what a nice looking little camera it is, also nothing to blame on packaging though there was no protective film on cameras or the LCD, but it is also a pre - production sample i have received. And it have put me in a damn dilemma, it is - 3 degrees outside and snow in the forecast for the...
dashcamtalk.com
The down side was this is 2 different systems with different boot times, so the footage was not in sync, but you would get that if you have 2 similar systems with similar settings.
Sadly there are not many dual remote systems on the market, these dont seem to be popular in most markets.
I put cameras on fixed glass in rear door, routed wire down thru door and rubber grommet to B pillar.
Ended up with this kind of 360 coverage.
